1 Reply Latest reply on Apr 30, 2008 8:50 AM by SiamJai
    speed of the animation
    milothe
      I have done animated message with fireworks. i have set frame delay higher to slow down the text movement.
      But after i export the file to .swf format, somehow the speed still very fast. Seems like i cannot control it.
      Does anyone know what went wrong?
        • 1. Re: speed of the animation
          SiamJai Level 2
          There are two places where frame delay is set; it's possible that one hidden default value overrode your setting.
          To fix that, try the following:
          1. Check the frame delay in Fireworks before exporting.
          2. If it's the right number, proceed with swf export as usual.
          3. Click on the Options button in the bottom right corner of the "Save As" window.
          4. Locate the last input field in the resulting Export Options window. This is the other place where frame rate is controlled, and it always defaults to the last-used fps value, regardless of your previously set frame delay. Just change this value to yours and click OK.
          I hope that helps,
          SiamJai
