4 Replies Latest reply on May 1, 2008 11:21 AM by gburgmalbert
    CFEXECUTE on Solaris Not Working
    gburgmalbert
      I'm trying to get a simple perl script to run via CFEXECUTE on a Unix box running CFMX 7.02 and have not been successful. I have spent considerable time searching and have not found a working solution.
      I have full control of the box and it's in a development environment behind a firewall. I've set permissions wide-open, moved the file, etc. and have not been able to get the cfexecute to work. The output file is blank. The file works on our CF5 instance (also unix).
      Any help would be appreciated.
      This is a simple perl script that simply inserts a record in an Oracle database - and works fine from the command line as the user the runs CF on the box. This is a basic test script I wrote to debug this issue.
      Here is the command:
      <CFEXECUTE name="/disk1/cnav0/bin/it_tools/test_script.pl"
      outputfile="/tmp/test_script.txt"
      timeout="30">
      </CFEXECUTE>
      I have tried:
      <CFEXECUTE
      name="/usr/local/bin/perl"
      arguments="/disk1/cnav0/bin/it_tools/test_script.pl"
      timeout="30">
      </CFEXECUTE>
