2 Replies Latest reply on Apr 30, 2008 4:39 PM by FreeMan04
    Flash display in captivate
    FreeMan04 Level 1
      Hi again people,
      I created a flash file and inserted it in captivate. The flash files contains 4 movie clips that is hidden (not on stage), and when I click on a button, the movie clip move from hidden to stage.
      Now, is all good until i insserted it in captivate and publish it. I can see the flash files plus all the 4 hidden clips.
      Can this be fixed?
      thanks
        • 1. Re: Flash display in captivate
          jojolina Level 1
          Smoke and mirrors
          I am assuming a button on your slide that you want to use to bring the swf into play, but the problem is that the swf is already displayed before the button is clicked??
          I can think of 2 options that might work:
          Have your swf appear after the button pause state in the timelin in Captivate (Animation Properties/Options/Appear After xx)
          Use a caption or screen image to "mask" the swf and set it to disappear 0.1s after the user has clicked the button.
          Hope this helps
          Andrew
          • 2. Re: Flash display in captivate
            FreeMan04 Level 1
            Hi Andrew,
            You are right, i built the swf file in flash with 3 buttons and movie clips hiding behind the stage, and when each of the button is clicked, the respective clip appears.
            I guess I can use a white jpg to mask out hidden clips but thats not the optimal solution.
            thanks anyway
