• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
HTML Client leads to blank screen
Explorer ,
May 29, 2019 May 29, 2019
I just changed my settings on my Connect meeting, so now HTML client is allowed.Later, I "forced" HTML client by adding the parameter "?html-view=true" at the end of meeting URL. My intention is to experience the full HTML Connect client.
What I get is a totally blank screen after login with my registered meeting account. This blank page has certainly some JS source code behind, but it is a total white page, anything happens.
Tested on several computers and browsers (all up to date). Anyone else having this issue?
Ignasi
TOPICS
HTML client , Meetings
Views
4.6K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , May 30, 2019 May 30, 2019
If you aren't getting the login screen, then you are logged in (session cookie) and Connect is just trying to launch the room because it knows who you are. Try using a private/incognito version of your browser. This will not use your existing browser cache giving you a more honest experience for joining the room.
Votes
Translate
Translate
Engaged ,
I would suggest instead that you use incognito mode in Chrome and when the room tries to launch into the app, cancel and then choose to view in browser on the next screen,   That should get you into the HTML5 version.  Soon that process will be smoother, but this is a better work around as that switch only works if you use other switches with it and this is simpler to do.
Votes
Translate
Translate
Report
Report
Explorer ,
Just tried what you told me, but I just get the same blank screen...
Votes
Translate
Translate
Report
Report
Engaged ,
Do you want me to try to join the meeting in HTML5?  I use HTML5 all the time in demoes without issue.  Also, are you using Chrome or Edge?
gunter@clarix.com
Votes
Translate
Translate
Report
Report
Explorer ,
I used:
· Chrome on Windows
· Safari on MacOS · Chrome on MacOS
Will send you the URL via e-mail, thanks
Ignasi
Votes
Translate
Translate
Report
Report
LEGEND ,
Try using a browser other than Chrome. Chrome likes to add to that query string for me so I end up with ?html-view=true&proto=true which calls to the HTML client and the Desktop App at the same time and nothing works. I just end up with the blank white page in Chrome.
In Fire Fox or Edge/IE the html-view=true call works better for me.
Votes
Translate
Translate
Report
Report
Explorer ,
I just tried with Firefox 67.0 in MacOS, and it adds this "proto=true" in the URL as well, so I get that blank page again and again
Votes
Translate
Translate
Report
Report
LEGEND ,
When you are joining the room, are you in a browser where you are already logged in to Connect? If so, do you have Host or Presenter rights to that room? If so then Connect won't launch the HTML version of Connect but instead try to force the App. This is because the HTML version is a Participant only view.
Votes
Translate
Translate
Report
Report
Explorer ,
In summary, after a lot of tests, here's what I found:
  • HTML client + Chrome in MacOS ==> adds proto=true, leads to blank page
  • HTML client + Safari in MacOS ==> adds proto=true, leads to blank page
  • HTML client + Firefox in MacOS, entering as registered user  ==> adds proto=true, leads to blank page
  • HTML client + Firefowx in MacOS, entering as Guest ==> Works just fine
It looks like under Edge in Windows works fine as well.
Votes
Translate
Translate
Report
Report
New Here ,
As a reminder, there is no option for the HTML client for HOST or PRESENTERS.  It's for PARTICIPANTS only.  So, if you are a HOST or have been given HOST/PRESENTER rights to the meeting room and you login with your Adobe Connect credentials, you will not be able to join in the HTML client.  If you login as a GUEST, you will be able to join in the HTML client (unless Promote All users to Presenter is used).
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks for the reminder.
I am trying to enter as GUEST forcing HTML client. Using Chrome of Safari (always MacOS) it's not possible. I can't even get into the login screen. Typing the room URL with the HTML parameter leads directly to the blank page dead end.
Same procedure under Firefox 67 works just fine.
Votes
Translate
Translate
Report
Report
Explorer ,
Chrome OR* Safari I meant...
Votes
Translate
Translate
Report
Report
LEGEND ,
Votes
Translate
Translate
Report
Report
Explorer ,
I tried entering as Guest in an Incognito window under Google Chrome (MacOS) ===> Works fine.
But then I did exactly the same using Safari and again I get the blank dead end page.
Keep trying, thanks!
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
Okay, after different tests, I was able to run the HTML client, of course only entering as Guest, and from Incognito windows of previously cache-cleaned browser windows. I only had this problem of blank page dead end under a computer with Safari version 10.1
With another computer with Safari 11 everything works just fine.
Thanks to everyone involved in this help !!
Votes
Translate
Translate
Report
Report
