5 Replies Latest reply on May 2, 2008 4:14 PM by kglad
    Scroll script works in Flash 6, but not in 9
    noba Level 1
      I have a simple scroller script that works fine for scrolling a movieclip in Flash 6, but when I publish in anything later, it no longer scrolls. Both are set to AS2. Is there an obvious reason that anyone can see of why this should be? When I test the script syntax in the actions panel, it says there are no errors in the script. By tracing I can see that there's no trouble with targeting the up and down buttons or scroll slider, and the slider still drags, but the content MC doesn't move as it should. Thank you very much for your help, in advance. Here's the script, in case the answer isn't obvious from the description:
