1 Reply Latest reply on Apr 28, 2008 7:54 AM by clbeech
    Loading external swf in a scrollpan
      Hello everyone.
      I have an issue that I am hoping someone can help me with.
      I am displaying an external diagram picture (swf) in a main scroll pan using AS2.0. I want to load some external objects (swf) on top of the diagram from another object scroll pan.
      My problem is when I am drag & drop the object from object scroll pan to main scroll pan the diagram picture get disappears. Please check following code.
      When I am loading the external swf object then the scroll pan is just loading 1 object at a time and not allowing to move the object.
      The external objects are not working so I have also tried with internal library, So when I am loading the objects from internal library then also it is removing the diagram.
      I appreciate any help.
        • 1. Re: Loading external swf in a scrollpan
          clbeech Level 3
          well sorry alvin - but I'm afraid there are several things wrong here. most prevalent are:
          1) in the Controls statement - the 'position' var should be an initObject
          2) Arrays in Flash are not associative in type and are 'ordered' arrays - you cannot specify a 'string' in the index accessor and this must be a number
          a few other things as well but these are the biggest issues.
