1 Reply Latest reply on May 2, 2008 3:04 PM by Newsgroup_User
    Problems decrypting a wddx string
    djc11
      Hey all, so i have a page that stores some data in a struct, i convert the struct to wddx, encrypt it and pass the string in a form field. On the action page i decrypt it but it's not decrypting correctly, which does not allow me to convert it back to a cfml struct. if i decrypt it and dump it out on the initial form page, it works fine. for some reason, it seems to have a problem only after being passed in the form. What am i doing wrong?
      As far as the lines to encrypt/decrypt, they seem like they must be right, because if i use them on the same page it works perfectly.
        • 1. Re: Problems decrypting a wddx string
          Level 7
          Are you encoding the encrypted string to pass it through the form
          submit? Encrypted strings often contain special characters that are not
          allowed in a http get or post header or body. These strings must be
          escaped to be properly passed.
          urlEncodeFormat() should probably be in your process somewhere. With
          the corresponding ...Decode() function on the other end.
