I am currently writing an Output aex plugin. It already works with outputting videos (AddFrame) but how do i get the sound samples?
A_Err (*AEIO_AddSoundChunk)(
AEIO_BasicData *basic_dataP,
AEIO_OutSpecH outH,
const A_Time *start,
A_u_long num_samplesLu,
const void *dataPV);
How do I get the samples?
Thank you.
P.S.: The function has a different signature in the header file than in the PDF. Am I missing something?
the sound samples are in "dataPV" and there will be "num_samplesLu" starting at time "start".
you can use AEGP_GetOutSpecSoundSampleSize, AEGP_GetOutSpecSoundChannels, and AEGP_GetOutSpecSoundEncoding with outH to get the bytes per sample, number of channels, and the format the samples are in. the samples will be interleaved.
I bet the sample data is in dataPV. But how in what format / structure? Anybody?
Check the file SDK_Backwards.cpp in the included SDK examples, it is a good starting point on how to check out audio tracks, modify/process them and write them back.
Thanks, but the thing is that the samples are stored in:
const void *dataPV
is of type "const void*". I need to know what I need to cast it to.
Yes, this area is undocumented and the current headers are inconsistent (e.g. using the undefiend AEIO_SndWorldH handle). You might try just dumping the data and opening it with an audio editor to see if it is always a certain raw format or actually the compressed audio stream according to the project/export settings. Probably only Adobe can help you here...
Adobe admitted on twitter the documentation needs to be corrected.
I guess the data might be different depending on the number of channels, sample format,... that's why it could be a void*. But it could be just anything. Is it packed or planar?
Yes, only Adobe can help here. Everything else is just guessing.
I assume that the intended method was to provide a handle "AEIO_SndWorldH" in the interface that actually points to a AEIO_SndWorld structure which has more detailed description of the current format, just like with pixel data. However this neither seems to be implemented nor documented (yet).
I got it working. Thank you.
Helpful info. Thanks.
