0 Replies Latest reply on Jun 18, 2008 9:21 AM by Advantage[Web]
    godaddy to authorize.net connection error
    Advantage[Web]
      I'm getting a "connection failure" error (IE, FF) trying to connection to authorize.net through a coldfusion test page on godaddy host account. I was told to use their proxy server. I have the following but still no connection..
      <cfhttp
      method="post"
      url="https://secure.authorize.net/gateway/transact.dll"
      proxyServer=" http://proxy.shr.secureserver.net"
      proxyPort="3128"
      <cfhttpparam name="x_login" type="formfield" value="xxxxxxx">
      <cfhttpparam name="x_tran_key" type="formfield" value="xxxxxxxxxxxxxxxx">
      </cfhttp>
      <cfset api_response=cfhttp.fileContent>
      <cfoutput>#api_response#</cfoutput>
      I was also told in another forum that..
      ..you may need to (have godaddy ssl cert team) manually import the certificate of authorize.net
      http://livedocs.adobe.com/coldfusion/7/htmldocs/wwhelp/wwhimpl/common/html/wwhelp.htm?cont ext=ColdFusion_Documentation&file=00000272.htm
      http://www.bpurcell.org/blog/index.cfm?mode=entry&entry=843
      Anyone out there have any more insight into this problem? How can I verify that they've manually imported the certificate of authorize.net?
