• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
puppets and scene no show
New Here ,
Jun 07, 2019 Jun 07, 2019
How can I fix this problem?
Views
497
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Jun 07, 2019 Jun 07, 2019
It usually occurs when the artwork file is moved, so the puppet points the wrong path name. If you select the puppet, one of the first properties is the path to the artwork. If the path is orange, it means the file could not be read. Click on it to locate the file in its new location.
Votes
Translate
Translate
LEGEND ,
Votes
Translate
Translate
Report
Report
New Here ,
oh my god thank you very  much and fast and correct answer
Votes
Translate
Translate
Report
Report
LEGEND ,
Here is a recent similar problem. Puppet looks like a test pattern  If you look at the top right corner of the screenshot you can just see the orange path name to the puppet. Once that was fixed it started working again.
Votes
Translate
Translate
Report
Report
New Here ,
Feb 14, 2022 Feb 14, 2022
 look what I got here ! I don't know why ! I need a solution it's my project ! Please I need help !
Votes
Translate
Translate
Report
Report
LEGEND ,
That happens when the project is moved (or the artwork is moved). Single click on the puppet in the project panel. The first "property" over on the right should be "Path". Click on that and re-open the artwork file with the correct path for the PSD/AI file.
Votes
Translate
Translate
Report
Report
New Here ,
I had a bigger problem I have a message now that the project is not found
in users/documents/….
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Sounds like files are moving or being deleted? Make sure you don't put your project on a network mounted drive (or have cloud sync etc running). It needs to be on a local drive with no cloud sync etc on it for most reliable resutls.
Votes
Translate
Translate
Report
Report
