4 Replies Latest reply on Aug 24, 2006 9:10 AM by ntsiii
    1119 - ERROR - Please Help
    rashmi123
      Please help me with this..
      I am getting the following error
      -- 1119: Access of possibly undefined property result through a
      reference with static type mx.rpc.http.mxml:HTTPService..
      The code i am using is as follows.. I am getting the the error in
      the line where the tag <mx:Model> is defined.. Pleae let me know if
      I can use the xml file, which is in my local computer when using the
      following code..
      data.xml file is in the D drive of my computer
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml"
      width="100%" height="100%"
      initialize="srv.send()">
      <mx:HTTPService id="srv" url="data.xml"/>
      <mx:Model id="results">{srv.result.data.result}</mx:Model>
      <mx:LineChart id="chart" dataProvider="{results}"
      showDataTips="true" width="100%" height="100%">
      <mx:horizontalAxis>
      <mx:CategoryAxis dataProvider="{results}"
      categoryField="month"/>
      </mx:horizontalAxis>
      <mx:series>
      <mx:Array>
      <mx:LineSeries yField="apple" name="Apple"/>
      <mx:LineSeries yField="orange" name="Orange"/>
      <mx:LineSeries yField="banana" name="Banana"/>
      </mx:Array>
      </mx:series>
      </mx:LineChart>
      </mx:Application>
        • 1. Re: 1119 - ERROR - Please Help
          frickin_chicken
          im new here and havent worked with datamodels but a quick look in the help file showed this as example syntax.
          <mx:Model source="employees.xml" id="employee1"/>
          or
          <mx:Model source=" http://www.somesitel.com/employees.xml" id="employee2"/>
          • 2. Re: 1119 - ERROR - Please Help
            manteratech
            You might want to try using lastResult as result is no longer supported after beta2 or 3.
            So your code looks like this.
            It should look like this.
            <mx:Model id="results">{srv.lastResult.data.result}</mx:Model>
            let me know if that works.
            Stephan
            • 3. Re: 1119 - ERROR - Please Help
              rashmi123 Level 1
              Thanks Manteratech. The solution given by you has worked. I am not getting the 1119 error.
              But there is one mor question to you.. Pls help me with this.
              In the above statement what is data.result ????? I have an XML file called data.xml and below are the contents..
              <data>
              <total month="Jan-03">
              <apple>200781</apple>
              <orange>225971</orange>
              <banana>161280</banana>
              </total>
              <total month="Feb-03">
              <apple>188249</apple>
              <orange>179611</orange>
              <banana>150795</banana>
              </total>
              <total month="Mar-03">
              <apple>229774</apple>
              <orange>214767</orange>
              <banana>189889</banana>
              </total>
              </data>
              ERROR - Error: Unknown Property: 'apple'.
              Please help me with this. Thanks
              • 4. Re: 1119 - ERROR - Please Help
                ntsiii Level 3
                I find Model difficult to use because I have never been clear on exactly how it serializes xml into the object structure.
                You should consider useing resultFormat="e4x".
                I'd also skip the tag and use a result handler to put the xml directly into a variable. That wasy you can use toXMLString() to inspect the structure of your XML so as to know how to reference the data you want.
                Note that in a result handler function use event.result, not lastResult.
                Tracy
