3 Replies Latest reply on Jan 20, 2009 3:35 AM by Newsgroup_User
    Order Confirmation Emails -
    Level 7
      Hi All.
      I have an orderconfirmation page that sends out an email to both the
      customer and myself.
      The page uses an include that sets the details for CDONTS and also the body
      of the email (see code below)
      All works fine, but now i want to send two versions of the confirmation
      email, one to the customer and one to myself. The reason for the need for
      two versions is that my version will have, in addition, a simple table with
      boder to allow me to add notes for processing reasons.
      When i put two includes on the order confirmation page (one for each email)
      only one is executed!! - and it's always the second include.
      I have to admit that im not too familiar with using functions, so i'm not
      even sure if this is possible.
      Please see code below:
      OrderConfirmation.asp
      <!--#include file="functions_email_ourcopy.asp" -->
      <!--#include file="functions_email.asp" -->
      SendEmail CustomersRS("CustomerEmail")
      Functions_email_ourcopy.asp
      'Start the functions
      function SendEmail(c)
      Set objMail = Server.CreateObject("CDONTS.NewMail")
      objMail.From = "me@work.com"
      objMail.To = c
      objMail.Bcc = ""
      objMail.CC = "" 'Maybe send a CC to your sales office
      objMail.Subject = "Order from Website"
      objMail.Body = Mailbody
      objMail.MailFormat=0
      objMail.BodyFormat=0
      objMail.Send
      Set objMail = Nothing
      end function
      function SiteRoot
      'This function tries to ascertain the site root. If it's wrong, enter your
      own manually
      CurrentPage=Request.ServerVariables("SCRIPT_NAME")
      SiteRoot=" http://" & Request.ServerVariables("SERVER_NAME") &
      left(CurrentPage,instrrev(CurrentPage,"/"))
      end function
      Function Mailbody
      'on error resume next
      Set objXML = Server.CreateObject("MSXML2.ServerXMLHTTP")
      ' Call the remote machine the request
      objXML.open "POST", SiteRoot & "email_ourcopy.asp", False
      objXML.SetRequestHeader "Content-Type", "application/x-www-form-urlencoded"
      objXML.send("OrderID=" & OrderID)
      ' return the response
      Mailbody = objXML.responsetext
      ' clean up
      Set objXML = Nothing
      End Function
      Functions_email.asp
      objMail.From = "sales@test4less.co.uk"
      objMail.To = c
      objMail.Bcc = ""
      objMail.Subject = "Order from Test4Less Website Customer Copy"
      objMail.Send
      end function
      function SiteRoot
      own manually
      end function
      Function Mailbody
      objXML.open "POST", SiteRoot & "email.asp", False
      ' clean up
      End Function
        • 1. Re: Order Confirmation Emails -
          Level 7
          Andy wrote:
          > Hi All.
          You are including the same function twice, then only sending one, the
          second time you include the function it overwrites the first, so when
          you call it, it only sends to the second one.
          The solution? Rename the function in the second one, then call it after
          you call the first one.
          SendEmail2 CustomersRS("CustomerEmail")
          You might end up with the same content in both, as you have another
          function called Mailbody that is defined twice, so you may need to
          rename that, and where it is called as well.
          Dooza
          • 2. Re: Order Confirmation Emails -
            bregent Most Valuable Participant
            Also, since you are rewriting these functions, now is probably a good time to switch over from CDONTS to CDOSYS.
            • 3. Re: Order Confirmation Emails -
              Level 7
              Hey - Thanks Dooza
              I will be working on this tomorrow and report back - much appreciated
              Regards
              Andy
              "Dooza" <doozadooza@gmail.com> wrote in message
              news:gkpufc$d2e$1@forums.macromedia.com...
              > Andy wrote:
              >> Hi All.
              >> body of the email (see code below)
              >> with boder to allow me to add notes for processing reasons.
              >> email) only one is executed!! - and it's always the second include.
              > second time you include the function it overwrites the first, so when you
              > function called Mailbody that is defined twice, so you may need to rename
              > Dooza
