• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Is there any xml structure for creating and applying group paragraph style?
Advocate ,
Jun 24, 2019 Jun 24, 2019
Hi all,
          I am looking for xml structure for directly applying styles from group style just like aid:pstyle="test", where if there's any style with name test will be applied directly and if there's none indesign will create one.
Do we have any such kind of xml structure for creating and applying style from a group styles?
Thanks in advance
Sunil
Views
2.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guide , Jul 04, 2019 Jul 04, 2019
My guess is that style groups have been added relatively later (CS4?) than XML import (CS3), and support for them by XML import was just not considered.
I currently see these possible approaches:
  1. File a feature request at Uservoice.
  2. Rearrange the styles to follow the observed limitations of the import feature.
  3. Write and use a post processing script for all kinds of adjustments after the import process. That script could for example utilize XML Rules or XPath features of InDesign's XML - which is dif
Votes
Translate
Translate
LEGEND ,
Which Adobe product are you asking about?
Votes
Translate
Translate
Report
Report
Advocate ,
I am looking for help in Adobe InDesign XML.
Currently InDesign is having two namespaces as : http://ns.adobe.com/AdobeInDesign/4.0/  for paragraph styles and character styles, And second http://ns.adobe.com/AdobeInDesign/5.0/  is for table structure.
My concern is for how to do it for Group styles (Paragraph style/Character style).
Best
Sunil
Votes
Translate
Translate
Report
Report
LEGEND ,
Moved to InDesign Forum.
Votes
Translate
Translate
Report
Report
Advocate ,
You don't need to move my question to that forum because I've already asked this question on that forum as well but din't receive any help from that forum.
I put that question on this forum thinking I might get some help from here if somebody is having any idea about that.
Sunil
Votes
Translate
Translate
Report
Report
Community Expert ,
It's doubtful. XML has very limited group of people using it in InDesign.
You will have more luck looking for scripts to do what you want if you can be more specific. Ask in the InDesign Scripting forum here:
InDesign Scripting.
Votes
Translate
Translate
Report
Report
Advocate ,
I understand Steve.
I have already asked this question on InDesign Scripting as well.
Hoping for good
Sunil
Votes
Translate
Translate
Report
Report
Advocate ,
@https://forums.adobe.com/people/Steve%20Werner
I can do that with InDesign JavaScript as well but If there's a xml structure for it why should I write code for the same.
If I don't get that XML I'll be writing InDesign JS only.
But reason behind searching for XML is that importing XML is much more faster than executing JS for applying such styles while going in a loop n all.
Sunil
Votes
Translate
Translate
Report
Report
Participant ,
Jun 25, 2019 Jun 25, 2019
please try this code
maptagToparastyle('*')
function maptagToparastyle(xmlElement)
    ruleSet = new Array (new AddReturns);
__processRuleSet(myDoc.xmlElements.item(0), ruleSet);
function AddReturns()
    this.name = "MapStyles";
    this.xpath = "//"+ xmlElement;
    this.apply = function(element)    {
        if (element.xmlAttributes.item("aid:pstyle").isValid){
            var style =  element.xmlAttributes.item("aid:pstyle").value
            if (myDoc.paragraphStyles.item(style).isValid)
                    element.texts[0].applyParagraphStyle(style);
Votes
Translate
Translate
Report
Report
Advocate ,
Hi priyak7746321​,
I am not looking for InDesign JavaScript (I can also write JS).
I am looking for xml structure for Paragraph/Character Group styles Just like there's a namespace for Adobe InDesign for applying paragraph style.
Just add this name space into your xml and import & you don't have write any code, while importing xml only InDesign will apply that paragraph style which is mentioned in that attribute.
If you have any Idea about Group style xml structure please share your knowledge, That would be a great help
Anyway I appreciate your efforts
Sunil
Votes
Translate
Translate
Report
Report
Participant ,
xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:aid="http://ns.adobe.com/AdobeInDesign/4.0/" xmlns:aid5="http://ns.adobe.com/AdobeInDesign/5.0/">
<p aid:pstyle="Ind">
I tried within para style group and its working fine for me.
Votes
Translate
Translate
Report
Report
Advocate ,
Hi priyak7746321
Can you share some screenshot?
Sunil
Votes
Translate
Translate
Report
Report
Advocate ,
Take a look at this,
This is before importing myGroup styles is : GroupStyle1
And this is after I imported XML: (Note: New style gets created named as per attributes : GroupStyle1 outside of group)
XML :
<?xml version='1.0' encoding='UTF-8'?><eduxml xmlns:aid="http://ns.adobe.com/AdobeInDesign/4.0/" xmlns:aid5="http://ns.adobe.com/AdobeInDesign/5.0/">
  <p aid:pstyle="GroupStyle1">Test Para For applying Group Style</p>
</eduxml>
If you have something, let me know...
Best
Sunil
Votes
Translate
Translate
Report
Report
Guide ,
  3. Write and use a post processing script for all kinds of adjustments after the import process. That script could for example utilize XML Rules or XPath features of InDesign's XML - which is different from the ExtendScript XML that you were using in the other forum thread.
  4. Use a different import format - a typical approach would be an externally run XSLT producing an ICML file.
  5. Write a plugin to implement own extensions to the XML import.
Votes
Translate
Translate
Report
Report
Advocate ,
Hi Dirk Becker​,
If xml import wasn't considered I'll leave this thread opened.
I'll write simply a loop of JS to reach my goal.
Thanks you
Sunil
Votes
Translate
Translate
Report
Report
Participant ,
other way convert the ICML  to BackingStory.xml (idml structure). It may solve the issue.
Votes
Translate
Translate
Report
Report
Community Beginner ,
Mar 14, 2020 Mar 14, 2020
<p aid5:pstyle="TextStyleGroup___Body Indent 1">Here, is your solution.</p>
TextStyleGroup: Use group name here
___: use seperator  (i have used 3 undersore, you can use any other)
Body Indent 1: Paragraph style
For complete referemce see my post rajesh_kumar4
Votes
Translate
Translate
Report
Report
Advocate ,
Mar 15, 2020 Mar 15, 2020
Hi rajesh_kumar4,
I think you did not read my question properly.
I am also able to write JavaScript to apply group paragraph styles, and also able to put 3 or 1000 underscores.
I am also able to write xslt as well.
My concern was is there any direct XML structure exists or not for applying group styles while importing XML like aid:pstyle.
The post your are refering is nothing but you are applying group paragraph styles from javascript, instead it is not applying those styles while importing into InDesign.
So as Dirk Becker​ suggested that this xml structure for group styles was not considered while developing those.
Dirk Becker​ says :
If you have any solution over that please share.
Sunil
Votes
Translate
Translate
Report
Report
Mar 16, 2020 Mar 16, 2020
It is beyond InDesign scope right now, for coming version it could be possible yoe may talk to Adobe Developer.
Votes
Translate
Translate
Report
Report
Advocate ,
LATEST
Yes,
Currently group paragraph styles is not being taken into considaration for XML.
Thanks for your time.
Sunil
Votes
Translate
Translate
Report
Report
Community Expert ,
By the way, have you looked at Adobe FrameMaker?
It can easily apply paragraph and character styles based on XML tags with an EDD.
With a conversion table, it can wrap XML tags based on para/char styles. (Conversion tables are relatively simple to make for most jobs.)
David Creamer: Community Expert (ACI and ACE 1995-2023)
Votes
Translate
Translate
Report
Report
Advocate ,
I am just wondering if any namespaces exists that while importing xml into InDesign, group style should applied.
If no currently I am using JavaScript to do that.
If I can get that XML structure for it, I will get rid off this looping code.
Sunil
Votes
Translate
Translate
Report
Report
