• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Escaping the : character
New Here ,
Aug 25, 2006 Aug 25, 2006
Hi
How do you escape the : character on the line below from an rss feed from yahoo weather ?
#XMLContent.rss.channel.item.yweather:condition.text.xmlText#
I have tried
['yweather:condition']
but I am still getting the error
Invalid CFML construct found on line 41 at column 39.
ColdFusion was looking at the following text:
TOPICS
Advanced techniques
Views
542
Translate
Translate
Report
Report
Community guidelines
community guidelines
Engaged ,
Use array notation!
#XMLContent.rss.channel.item["yweather:condition"].text.xmlText#
Votes
Translate
Translate
Report
Report
New Here ,
Thanks that seems to have solved that problem but has resulted in me getting another CF error
I am using
#XMLContent.rss.channel.item["yweather:forecast day"].xmlText#
based on item elements from
http://developer.yahoo.com/weather/#item
I am getting the CF error
Error Occurred While Processing Request
Element yweather:forecast day is undefined in a Java object of type class coldfusion.xml.XmlNodeList referenced as
41 : #XMLContent.rss.channel.item["yweather:forecast day"].xmlText#
42 :
43 : </cfoutput>
Is my RSS syntax incorrect?
Votes
Translate
Translate
Report
Report
Engaged ,
Have you parsed your xml yet? If not use xmlParse(), if you have dump XMLContent and look at the structure!
Votes
Translate
Translate
Report
Report
New Here ,
Yes I have, and have dumped the results
The problem I have is how do you display the element attributes ? this is what is causing me the error
the forecast part of the xml doc has attributes such as code, date, day, high, low etc....
How could I add the 'day' attribute which is an attribute of 'forecast' for example to the line below
#XMLContent.rss.channel.item["yweather:forecast"].xmlText#
Votes
Translate
Translate
Report
Report
Engaged ,
LATEST
XMLContent.rss.channel.item["yweather:forecast"].xmlAttributes.day
Votes
Translate
Translate
Report
Report
Resources
Documentation
