13 Replies Latest reply on Jan 2, 2009 6:00 AM by Newsgroup_User
    IE Rollover Problem in Frame
    NoHandleBars
      I would appreciate assistance in resolving a rollover problem which exists only in all versions of IE but works fine in FF, Opera, Safari, and Chrome. You can see the page at http://www.moriel.org/Moriel_USA/Moriel_USA.html.
      This is a frameset where the rollover menu in the left sidebar automatically loads the page in the main section to the right. In IE it loads the rollover on the wrong line (1 below where it should be) but still correctly loads the page on the right.
      I'm sure I'm not the first to experience this but just can't seem to locate the solution. Any help would be much appreciated. Thanks!
        • 1. Re: IE Rollover Problem in Frame
          Level 7
          Pardon me for saying this but that is simply an awful way to make a website.
          It suffers from all of the usual disadvantages of frames (there is no reason
          at all for using them here), in addition to the fact that each rollover
          required an entirely new page to load in the central frame (i.e., long -
          LONG - delay).
          In addition, your use of Java on one of the pages ensures that a great many
          of your visitors will not see the contents there. That, combined with your
          use of an all javascript menu in the top navigation frame -
          <script type="text/javascript" language="JavaScript1.2"
          src="../Scripts/MainNav.js"></script>
          means that your site won't be spidered at all. Sorry - but I think your
          site layout architecture defeats the very purpose of the site.
          I don't see any rollover problem in IE7.
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          "NoHandleBars" <webforumsuser@macromedia.com> wrote in message
          news:gjirk2$hjp$1@forums.macromedia.com...
          >only
          > can
          > automatically
          > rollover on
          > page
          > on the right.
          > locate
          • 2. Re: IE Rollover Problem in Frame
            Level 7
            > website. It suffers from all of the usual disadvantages of frames (there
            > is no reason at all for using them here), in addition to the fact that
            > each rollover required an entirely new page to load in the central frame
            > (i.e., long - LONG - delay).
            > many of your visitors will not see the contents there. That, combined
            > with your use of an all javascript menu in the top navigation frame -
            I must agree with Murray with the added caveat:
            Users don't expect a rollover to load urls, they would normally click
            the link.
            Mick
            • 3. Re: IE Rollover Problem in Frame
              NoHandleBars Level 1
              In reading another site I resolved the issue so I'll post it here just in case anyone does the same thing in the future.
              When naming each rollover they need to be numbered beginning with "0" instead of being given unique names in the "Image Name" filed of the "Insert Rollover Image" dialog box.
              • 4. Re: IE Rollover Problem in Frame
                Level 7
                That's nonsense.
                news:gjj1of$psu$1@forums.macromedia.com...
                > case
                > instead
                > Rollover
                > Image" dialog box.
                • 5. Re: IE Rollover Problem in Frame
                  Level 7
                  On Thu, 1 Jan 2009 13:32:19 -0500, "Murray *ACE*"
                  <forums@HAHAgreat-web-sights.com> wrote:
                  >That's nonsense.
                  You are correct. However, using names with spaces in them will reek havoc
                  with them.
                  Gary
                  • 6. Re: IE Rollover Problem in Frame
                    Level 7
                    Assuming you mean "wreak", yes, that too! 8)
                    If not, then your suggestion reeks.
                    "Gary White" <reply@newsgroup.please> wrote in message
                    news:2l3ql4tefhrt1u6h7rhk94t7kajdv9hop4@4ax.com...
                    >>That's nonsense.
                    > with them.
                    > Gary
                    • 7. Re: IE Rollover Problem in Frame
                      Level 7
                      >> That's nonsense.
                      > with them.
                      > Gary
                      Not really.
                      document.images["image name here"].onmouseover=function(){...}
                      Should work fine. No havoc *wreaking* there.
                      Mick
                      • 8. Re: IE Rollover Problem in Frame
                        I just replicated this EXACT solution on 6 additional pages which all now work. And I didn't have spaces in the names to begin with, but did have an underscore. Hope this helps...
                        • 9. Re: IE Rollover Problem in Frame
                          Level 7
                          You cannot begin a name attribute with a number. You may think it works,
                          but it won't be reliable.
                          news:gjj4lq$j3$1@forums.macromedia.com...
                          • 10. Re: IE Rollover Problem in Frame
                            Level 7
                            On Thu, 1 Jan 2009 13:44:51 -0500, "Murray *ACE*"
                            Using names with spaces in them reeks, no?
                            Gary
                            • 11. Re: IE Rollover Problem in Frame
                              Level 7
                              On Thu, 01 Jan 2009 13:58:02 -0500, Michael White
                              <mwhite13@rochester.rr.com> wrote:
                              >Not really.
                              Hmmm ... I've run into problems before with js and spaces in names.
                              Perhaps it was file names with spaces that were the problem. I've avoided
                              spaces in both for so long now that I don't remember for certain.
                              Gary
                              • 12. Re: IE Rollover Problem in Frame
                                Level 7
                                >> Not really.
                                > Gary
                                A js variable can not contain spaces, but an object's property can if it
                                is enclosed in brackets. Even a global object:
                                window["The Meaning of Life"]=41.9
                                Mick
                                • 13. Re: IE Rollover Problem in Frame
                                  Level 7
                                  On Thu, 01 Jan 2009 19:48:52 -0500, Michael White
                                  You are talking about a js variable name cannot contain spaces, right?
                                  That just seemed so obvious that I wanted to make sure I understood. I
                                  think what I may have been remembering was something like:
                                  window.open("a page name with spaces.html");
                                  However, testing it now, it seems to work. Perhaps it was in older
                                  browsers. I dunno, I'm getting way too forgetful any more.
                                  Gary
