• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Premiere crashes after 13.1.3 update
Explorer ,
Jul 12, 2019 Jul 12, 2019
Hi I'm on Windows 10 with an NVidia Geforce GTX 1060 gfx card. After the 13.1.3 update today, Premiere and After Effects both crash at the startup screen. I've done a full wipe using the adobe cleaner too and reinstalled, full wipe of gfx driver and reinstalled, deleted all temp and cache files, and even spoken directly to adobe tech support, and there is apparently no solution to this. The most I got out of tech support is that they think it has to do with my gfx card or driver but they have no solution.
I'm on 10 hours straight trying to fix this and a day behind work. I've already googled it to death and tried every solution to this problem going back years. Nothing works. Please help.
Views
11.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee , Jul 16, 2019 Jul 16, 2019
We found the cause of the Premiere Pro 13.1.3 crash on launch when running on Windows.  We are currently testing a fix.  In the meantime, we are providing a work-around, which you can find here:
https://adobe.ly/2LY4cjx
Votes
Translate
Translate
Explorer ,
I also can't simply roll back because the newest version you can roll back to is 13.0.3, which obviously cannot read my 13.1.2 project file. Adobe's only answer to that was that I can convert the project to 13.0.3 and lose all my color adjustments, transitions, and captions. Unacceptable.
Votes
Translate
Translate
Report
Report
New Here ,
Jul 13, 2019 Jul 13, 2019
Having same issue here.  Wasn't aware there was an update.  Now it makes sense.  Need help!  Going to attempt to use 13.1.2
Votes
Translate
Translate
Report
Report
New Here ,
I'm having the same problem. Premiere Pro and After Effects are consistently crashing during start-up. I'm using a Geforce GTX 1660 Ti. I tried going back to version 13.03, in which Premiere Pro does start up, but then my current project file isn't compatible and won't load.
Votes
Translate
Translate
Report
Report
Community Expert ,
Reboot,
deinstall,
reboot,
Use the Adobe Creative Cloud Cleaner Tool to solve installation problems
reboot,
reinstall.
See how that goes.
Votes
Translate
Translate
Report
Report
Explorer ,
I did all this already, same problem.
Votes
Translate
Translate
Report
Report
Explorer ,
Downgrading the project file is not a solution because I will lose multicam sequences and color correction.
Votes
Translate
Translate
Report
Report
Enthusiast ,
I have learned from past experience not to update Premiere until the User Forum does not show any problems with the latest update?
Votes
Translate
Translate
Report
Report
Community Expert ,
No problems here: 13.1.3 has some major bugfixes.
Votes
Translate
Translate
Report
Report
Explorer ,
It looks like this problem is mainly affecting Nvidia users, and particularly the GTX 1060 series. Adobe where are you on this?
Votes
Translate
Translate
Report
Report
Explorer ,
I avoid updates like the plague but the latest Creative Cloud app update seems to have set all my apps to auto-update by default. Very bad move on Adobe's part. This is a recurring problem for people going back many years.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
When you crash, do you get Adobe Crash Reporter interface come up asking you to submit crash report and logs?
If yes, have you submitted such crash reports?Did you include your name?
If crash reporter came up and you didn't send crash log, would you cause this crash and submit crash log?
Make sure to include your name, email, and check other boxes that provides additional info.
That helps us check the crash log and determine what is causing these crashes.
Also short description of the problem is always helpful.  Even if all it says is that it crashed during startup.
Votes
Translate
Translate
Report
Report
Explorer ,
I have sent several crash reports but did not include that info, so I'll do that now. Thank you.
Votes
Translate
Translate
Report
Report
Explorer ,
A great short-term solution would be to provide a download link for Premiere version 13.1.2. That's the version that my most recent project files are at, but you can only roll back to 13.0.3 in the CC app. If I could get back to 13.1.2 I'd be good to go for now.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
I'm looking into that option for you.
Votes
Translate
Translate
Report
Report
New Here ,
Dec 27, 2019 Dec 27, 2019
LATEST
Love this idea. offer us a quick solution instead of spending hours of our work day going through forums trying to find solutions.
Votes
Translate
Translate
Report
Report
New Here ,
I also have the nvidia 1060!
Votes
Translate
Translate
Report
Report
Community Expert ,
Have you tried clearing preferences? (Hold Alt+Shift while launching Premiere)
If you have plugins installed, try uninstalling those plugins.http://joshcluderay.com/downgrade-premiere-project-converter/
Also, use this to to downgrade your project and open it with older PP versions: Premiere Project Downgrader - Free prproj Version Convert
Votes
Translate
Translate
Report
Report
Community Expert ,
Knowing that it is not such a simple possibility I tell you because it is what I would at least do. Sometimes when you already have a lot of time with the same installation where you have installed and uninstalled many applications, copied, pasted, moved and deleted many files, among other things, it is a good idea to backup all files either in the cloud or on physical discs and give a complete and clean format to our system. There are things that get out of hand with respect to computer systems and they usually need a purge. It is not the first option to solve an issue but after reading the comments I think that what I say is just what you need. After formatting and updating all your drivers you do a clean installation of Premiere Pro and if your hardware and software are in good condition there is no reason why it does not work well.
Note: this is a suggestion and depends on you if you do it or not under your responsibility, or leave to a professional do it.
Votes
Translate
Translate
Report
Report
New Here ,
I literally received my current computer yesterday. I have updated the drivers to my graphics card and I had not opened After Effects on this computer before. I don't see why I need to be "purging" anything, but would rather see Adobe actually address this problem.
Votes
Translate
Translate
Report
Report
New Here ,
I had the same problem!! My Premiere crashes!!! Go to 13.1.4 NOW!!!!
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Can you run the System Compatibility Report from the Help menu, or if you see it at launch, then click on the "Save..." button to generate a text report which you can share?  Looking at the crash dump, it appears to be crashing in the Intel driver, so knowing the versions of your installed Nvidia and Intel drivers will be of great assistance.
Brian
Votes
Translate
Translate
Report
Report
Explorer ,
Brian
Which help menu? If you mean in Premiere, I can't get past the splash screen.
Votes
Translate
Translate
Report
Report
Explorer ,
coolguy8484  wrote
Brian
I've also tried updating every Intel component driver and tried several different Nvidia drivers going back to December of last year. Same problem. Currently I'm using the latest Nvidia Studio driver version 430.86.
Votes
Translate
Translate
Report
Report
Explorer ,
Brian
In reference to the system compatibility report screen, I googled to see which menu this was and I see that it's this screen:
System Compatibility Report Error. "UPDATED"
I only got that screen when I was testing older Nvidia drivers to see if any of them would work. I don't get this screen at at all on the latest driver. I get the normal splash screen, and then the lighter grey crash report screen.
Votes
Translate
Translate
Report
Report
