1 Reply Latest reply on Aug 24, 2006 6:51 AM by pipeski
    asp or xml?
    rohai Level 1
      I'm creating a flash based web site. For communication with DB I'm using asp. When is better to use direct communication between flash and asp and when is better to use xml (it's created by asp) to communicate with flash?
      THX for your help
        • 1. Re: asp or xml?
          pipeski
          There's probably no definitive rule on when to use XML.
          In general though, think about whether the data you're exchanging is ever likely to be delivered to other front-ends, and whether another developer might need to understand how your data is structured.
          If neither scenario is likely, you should probably just go with whatever is most convenient and quick.
