9 Replies Latest reply on Sep 19, 2006 7:24 PM by Newsgroup_User
    Space between letters
    nevilletu
      I have just started using fireworks so this is probably a silly question. When I enter text it looks like I put a space between each letter. Text looks l i k e t h i s no matter what font I use. Played with kearning which didnt seem to help. What am I missing?
        • 1. Re: Space between letters
          Level 7
          Set Kerning back to 0.
          Linda Rathgeber [PVII] **Adobe Community Expert-Fireworks**
          http://www.projectseven.com
          Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
          CSS Newsgroup: news://forums.projectseven.com/css/
          Design Aid Kits: http://www.webdevbiz.com/pwf/index.cfm
          • 2. Re: Space between letters
            Level 7
            And make sure you are not using Justify Alignment
            • 3. Re: Space between letters
              nevilletu Level 1
              Tried that but it still spreads the text. Another thing. I have to hit the space bar twice to get a space between words.
              • 4. Re: Space between letters
                Level 7
                Tried which? Both suggestions? What font are you using? What version of
                Fireworks? Can you post a link to the png file?
                Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
                Extending Knowledge, Daily
                http://www.communityMX.com/
                CommunityMX - Free Resources:
                http://www.communitymx.com/free.cfm
                .:Adobe Community Expert for Fireworks:.
                news://forums.macromedia.com/macromedia.fireworks
                news://forums.macromedia.com/macromedia.dreamweaver
                • 5. Re: Space between letters
                  nevilletu Level 1
                  The file can be downloaded from http://www.projectperfect.com.au/fireworks.zip I am using fireworks mx and the font is Arial Black size 9 although I have tried a number of fonts. I had been using Paintshop Pro using Aerial Rounded MT Bold which I didnt have on Fireworks but this was close. Unfortunately, the client wants to use Fireworks which I have not used before. Unfortunately, the client wants to use Fireworks which I have not used before.
                  I am trying to make some images to use for headings on a web page. The yellow background is intended to be used in a number of headings with different text. At this stage it is much longer than I want due to the text being so spread out.
                  • 6. Re: Space between letters
                    Level 7
                    nevilletu,
                    Your 'Text Orientation' is set to 'Vertical - Left to Right'. You can
                    make these changes to your existing text.....
                    http://tinyurl.com/hultm
                    Or, start new text with the settings changed.
                    This should be available for Fireworks also.
                    SKB
                    • 7. Re: Space between letters
                      Level 7
                      There is nothing unfortunate about using Fireworks, other than the fact
                      you are stuck with a much older version. ;-)Take the time to learn the
                      app and you'll see why it's so popular.
                      As for the graphic, your text orientation is vertical rather than
                      horizontal - that is why you are getting the gaps. Set the orientation
                      to horizontal, change the alignment to left or center and set your
                      kerning back to 0.
                      kerning back to 0.
                      • 8. Re: Space between letters
                        nevilletu Level 1
                        Thanks a lot guys. That solved the problem. I would never have found that one. Incidentally, I did not mean it was unfortunate that I was using Fireworks rather than Paintshop Pro because of the functionality. I meant it was unfortunate that the client wanted someone with no Fireworks skills to use the product. I am sure Fireworks is an excellent package. I use Dreamweaver and love it so I am sure Macromedia would produce an equally good graphics package.
                        • 9. Re: Space between letters
                          Level 7
                          Glad we could help. Keep brushed up on those FW skills . . . it'll come
                          in handy. :-)
                          Jim Babbage - .:CMX:. & .:Adobe Community Expert:.
                          Community MX
