Hi all
When you say "Configure for limited output", are you
referring to using Conditional Build Tags? If so, this would seem a
bit on the odd side. Why? Well, if a topic has been excluded via a
build tag and that topic is part of the TOC or Index, the TOC or
Index link should be removed as a result.
However, you also mention WebHelp Pro. Are you really using
WebHelp Pro with the RoboEngine?
I do know that when using the normal publishing features
available with generic WebHelp, that the process will never delete
files. This means that if you published at some point in time and
that topic is later removed from the project (either by deleting it
outright or by using build tags and a build expression, it will
remain on the server. So I'm guessing that this is happening. It's
not really part of the project in this case, but the RoboEngine
search mechanism is still finding it, right?
If this is the case, you will need to manually remove the
topic from the server.
If I've missed the mark here, let me know and I'll try to do
better.
Cheers... Rick
