2 Replies Latest reply on Aug 24, 2006 1:12 PM by jASP.Net
    Help Files Won't Load In Web Broswer
    jASP.Net
      We recently moved our web site and I moved over all of our help files. Whenever I try to view these files through Internet Explorer, the opening page seems to just keep trying to load (like an endless loop). I am 90% sure that it has to do with a setting in IIS because of the following:
      1. I can view the files just fine if I view them in Windows Explorer.
      2. I tried creating a "test" group of Help files and they work fine on another web server that I have, but don't work on this particular one.
      I am wondering if anyone has any insight on this? I am running a Virtual Private Server with Win2003, IIS 6. If you want to look at what the files are doing, please go to http://www.basic-software.com/80help/80help.html.
      This is a matter of urgency, so your reply, suggestions, are greatly appreciated!
        • 1. Re: Help Files Won't Load In Web Broswer
          jASP.Net Level 1
          OK - Since no one else is responding on the forum to this, I have an update -- I found out that if I remove these lines from the opening page it will load my help files, but it doesn't show the opening URL like before -- Any clue again as to why this works on our other server, but not on this one?
          <script type="text/javascript" language="javascript" >
          if (!window.gbWhVer||!window.gbWhUtil||!window.gbWhMsg)
          document.location.reload();
          </script>
          • 2. Re: Help Files Won't Load In Web Broswer
            jASP.Net Level 1
            In the event someone else has this issue, here is the Solution:
            IIS 6 does not serve unregistered MIME types like its predecessors. To fix this, in IIS go to the Properties of your website -- click MIME types -- Add * as the extension and register it as application/octet-stream That fixes it!
