1 2 Previous Next 73 Replies Latest reply on Aug 25, 2006 11:24 AM by Newsgroup_User
    Constrain To Sprite doesn't like rotating sprites...
    Level 7
      I have a bunch of movable sprites that I'd like to constrain to a box
      (basically just the whole stage). Problem is that they also have the
      ability to rotate, only at 90 degree intervals, though. They're relatively
      rectangular shapes (puzzle pieces). But when you rotate them with the
      Constrain to Sprite behavior on them, their aspect ratio gets all screwed
      up, and then sometimes they start moving on their own until they hit an
      edge, quite odd behavior. Is there a way to make this behavior work with
      sprites that can be rotated without these glitches? Or is there a better
      alternative? I tried writing my own contstrain script, which worked except
      that you could still drag the sprites off the edge, they'd just keep
      bouncing back and forth until you released the mouse button. Also not good
      behavior.
        • 1. Re: Constrain To Sprite doesn't like rotating sprites...
          Level 7
          Are you dragging these sprites around or are you moving them in some
          other way?
          If you are dragging the sprites around then you can use
          sprite(X).within(Y) to keep your sprites from leaving the stage area.
          1. Make a borderless empty toolbox shape sprite that is slightly smaller
          than the whole stage. Make is sprite 1.
          2. constrain each sprite to that sprite.
          3. use a simple behavior like this to control the moving of each sprite:
          property thisSprite
          property animateMe
          on beginSprite me
          thisSprite = me.spriteNum
          animateMe = false
          sprite(thisSprite).constraint = 1
          end
          on mouseDown me
          animateMe = true
          end
          on mouseUp me
          animateMe = false
          end
          on exitFrame me
          if animateMe then
          sprite(thisSprite).loc = the mouseLoc
          end if
          end
          Rob
          _______
          Rob Dillon
          Adobe Community Expert
          http://www.ddg-designs.com
          412-243-9119
          http://www.macromedia.com/software/trial/
          • 2. Re: Constrain To Sprite doesn't like rotating sprites...
            Level 7
            > other way?
            They're being dragged around by the mouse. (Actually a touch-screen, but
            that doesn't change things much.) As for your behavior, it looks like this
            will make the sprites snap back onto the stage on mouseUp, but it won't
            prevent people from dragging them out of the stage to begin with. It's
            similar to my first attempt in that respect. So far, only the default
            Constrain behavior in Director has actually prevented me from dragging them
            off the stage, but given the way it behaves with rotations, it's completely
            unusable in this case.
            • 3. Re: Constrain To Sprite doesn't like rotating sprites...
              Level 7
              Have you tried it?
              Rob
              _______
              Rob Dillon
              412-243-9119
              • 4. Re: Constrain To Sprite doesn't like rotating sprites...
                Level 7
                > Have you tried it?
                Well, I had to alter it, because I want you to be able to grab the sprite
                from anywhere, and have the part you grabbed stay under the mouse. It's
                better, but you can still drag sprites half-way off the screen.
                The code I added went something like this:
                on mouseDown me
                me.grabPoint = the mouseLoc - sprite(thisSprite).loc
                end
                and:
                if animate then
                sprite(thisSprite).loc = the mouseLoc - me.grabPoint
                end if
                Any way to make sure the sprites always stay 100% on the screen? The
                Constrain to Sprite behavior does it somehow, despite its other flaws.
                • 5. Re: Constrain To Sprite doesn't like rotating sprites...
                  Level 7
                  I got part of the way there by adding this:
                  on enterFrame me
                  if thisSprite.right > 805 then thisSprite.locH = thisSprite.locH -
                  (thisSprite.right-800)
                  if thisSprite.left < -5 then thisSprite.locH = thisSprite.locH -
                  (thisSprite.left)
                  if thisSprite.bottom > 605 then thisSprite.locV = thisSprite.locV -
                  (thisSprite.bottom-600)
                  if thisSprite.top < -5 then thisSprite.locV = thisSprite.locV -
                  (thisSprite.top)
                  end
                  (Stage is always 800x600, I allowed for 5 pixel bleed on the edges.) This
                  behavior is what I was using the first time before I tried the Constrain to
                  Sprite. I had to put this on the enterFrame, not the exitFrame, because on
                  the exitFrame, it will keep jumping back and forth every frame, which is
                  bad. What happens now is you can drag it half-way off the stage, but when
                  you release the mouse, it snaps back to the edge. I'd rather not be allowed
                  to drag it off in the first place, but this is definitely an improvement.
                  Only problem is sometimes when you rotate a piece such that it goes off the
                  edge, it will do the snap, and no longer be under the mouse. But that's
                  livable.
                  • 6. Re: Constrain To Sprite doesn't like rotating sprites...
                    Level 7
                    What you have to do is to make the constrainer sprite smaller than the
                    stage size. The constraint method is looking a the registration point of
                    the sprite that you are dragging. For a bitmap, this is at it's center.
                    So, at a minimum, you want that constrainer to be inside the stage by at
                    least half the width of the sprite that you are dragging.
                    Rob
                    _______
                    Rob Dillon
                    412-243-9119
                    • 7. Re: Constrain To Sprite doesn't like rotating sprites...
                      Level 7
                      Rob
                      _______
                      Rob Dillon
                      412-243-9119
                      • 8. Re: Constrain To Sprite doesn't like rotating sprites...
                        Level 7
                        Yeah, I was kind of seeing that - problem is that the pieces aren't all the
                        same size and shape, and there can be as many as 100 of them. Plus, when
                        they rotate 90 degrees, their aspect ratio is reversed. (e.g.: 3:4 becomes
                        4:3) Unless I had a seperate constrainer for every single piece, or altered
                        the constrainer depending on what piece you were moving... Actually, that
                        might just work, I'd have to change the rect of the constrainer on
                        mouseDown, keeping it exactly half the sprite's width from the sides and
                        half the height from the top and bottom. Only problem is when a sprite is
                        rotated 90 or 270 degrees, the height is actually the width and vice versa,
                        so I'd have to account for that, too... Do-able, but sounds like it's more
                        complex that it needs to be. Unless you know a simpler way...
                        • 9. Re: Constrain To Sprite doesn't like rotating sprites...
                          Level 7
                          Rob
                          _______
                          Rob Dillon
                          412-243-9119
                          • 10. Re: Constrain To Sprite doesn't like rotating sprites...
                            Level 7
                            • 11. Re: Constrain To Sprite doesn't like rotating sprites...
                              Level 7
                              Rob
                              _______
                              Rob Dillon
                              412-243-9119
                              • 12. Re: Constrain To Sprite doesn't like rotating sprites...
                                Level 7
                                • 13. Re: Constrain To Sprite doesn't like rotating sprites...
                                  Level 7
                                  Well, it works pretty well. It's still a little weird when you rotate a
                                  piece near the edge, but this is probably the best it's going to get.
                                  Thanks.
                                  • 14. Re: Constrain To Sprite doesn't like rotating sprites...
                                    Level 7
                                    Rob
                                    _______
                                    Rob Dillon
                                    412-243-9119
                                    • 15. Re: Constrain To Sprite doesn't like rotating sprites...
                                      Level 7
                                      • 16. Re: Constrain To Sprite doesn't like rotating sprites...
                                        Level 7
                                        Thanks.
                                        • 17. Re: Constrain To Sprite doesn't like rotating sprites...
                                          Level 7
                                          Rob
                                          _______
                                          Rob Dillon
                                          412-243-9119
                                          • 18. Re: Constrain To Sprite doesn't like rotating sprites...
                                            Level 7
                                            • 19. Re: Constrain To Sprite doesn't like rotating sprites...
                                              Level 7
                                              Thanks.
                                              • 20. Re: Constrain To Sprite doesn't like rotating sprites...
                                                Level 7
                                                Rob
                                                _______
                                                Rob Dillon
                                                412-243-9119
                                                • 21. Re: Constrain To Sprite doesn't like rotating sprites...
                                                  Level 7
                                                  • 22. Re: Constrain To Sprite doesn't like rotating sprites...
                                                    Level 7
                                                    Thanks.
                                                    • 23. Re: Constrain To Sprite doesn't like rotating sprites...
                                                      Level 7
                                                      Rob
                                                      _______
                                                      Rob Dillon
                                                      412-243-9119
                                                      • 24. Re: Constrain To Sprite doesn't like rotating sprites...
                                                        Level 7
                                                        • 25. Re: Constrain To Sprite doesn't like rotating sprites...
                                                          Level 7
                                                          Thanks.
                                                          • 26. Re: Constrain To Sprite doesn't like rotating sprites...
                                                            Level 7
                                                            Rob
                                                            _______
                                                            Rob Dillon
                                                            412-243-9119
                                                            • 27. Re: Constrain To Sprite doesn't like rotating sprites...
                                                              Level 7
                                                              • 28. Re: Constrain To Sprite doesn't like rotating sprites...
        Level 7
        Thanks.
        • 29. Re: Constrain To Sprite doesn't like rotating sprites...
        Level 7
        Rob
        _______
        Rob Dillon
        412-243-9119
        • 30. Re: Constrain To Sprite doesn't like rotating sprites...
        Level 7
        • 31. Re: Constrain To Sprite doesn't like rotating sprites...
        Level 7
        Thanks.
        • 32. Re: Constrain To Sprite doesn't like rotating sprites...
        Level 7
        Rob
        _______
        Rob Dillon
        412-243-9119
        • 33. Re: Constrain To Sprite doesn't like rotating sprites...
        Level 7
        • 34. Re: Constrain To Sprite doesn't like rotating sprites...
        Level 7
        Thanks.
        • 35. Re: Constrain To Sprite doesn't like rotating sprites...
        Level 7
        Rob
        _______
        Rob Dillon
        412-243-9119
        • 36. Re: Constrain To Sprite doesn't like rotating sprites...
        Level 7
        • 37. Re: Constrain To Sprite doesn't like rotating sprites...
        Level 7
        Thanks.
        • 38. Re: Constrain To Sprite doesn't like rotating sprites...
        Level 7
        Rob
        _______
        Rob Dillon
        412-243-9119
        • 39. Re: Constrain To Sprite doesn't like rotating sprites...
        Level 7
        1 2 Previous Next
