Hi Ralph and welcome to our community
When you recorded your movie, (well, actually
before you recorded your movie) you probably selected the
mode you used. There are four choices you see when you click
Options > Recording Options... > Recording Options tab and
click the Recording mode drop-down. You probably have one of the
simulation types selected. If you set Demonstration as the mode, it
should do what you want the next time you record.
This leaves the question of how to change or correct the
existing movie. In those simulation modes, a special object called
a "click box" is added to each slide where you clicked the mouse
while recording. So your task to correct that is to edit each
slide, locate the click box and remove it. This should make the
movie just play through. There is probably one other thing you will
want to do though. When you record in simulation mode, you also
don't see the mouse movement. So you may want to click a slide in
the Film strip (or switch to Storyboard view) press Ctrl+A to
select all slides, right click and turn the mouse back on. (click
Mouse > Show Mouse)
Hopefully this helps... Rick
