1 Reply Latest reply on Oct 20, 2006 12:56 AM by Newsgroup_User
    increment properties
    andylt1
      ok here's my querie.
      please be aware that i am new at coding and just starting to get to grips with it.
      now how would i
      1. setup a rollover to blend from 0 to 100 on mouse over to an over image
      2. move a button to a certain point on mouse over
      i currently am able to setup a rolover to swap an image and it just snaps on and off. and able to move an image to a certain point (say plus 10 in x) which also just pops.
      so how do i increment this type of action to go from a to b hope this makes sense
      any advice or directions to a tut would be great
      thanx
        • 1. Re: increment properties
          Level 7
          Hi Andy,
          I have Director tutorials at:
          http://www.fbe.unsw.edu.au/learning/director/
          Don't have any specifivally on what you're answering but here's some info.
          on mouseEnter me
          sprite(me.spriteNum).blend = 100
          end
          on mouseLeave me
          sprite(me.spriteNum).blend = 0
          end
          The above will set the blend to 100 when you move teh cursor over the sprite and
          back to 0 when you move off it.
          sprite(me.spriteNum) is a way of identifying the sprite that the behavior is
          atatched to.
          on mouseEnter me
          sprite(me.spriteNum).locH = sprite(me.spriteNum).locH + 200
          sprite(me.spriteNum).locV = sprite(me.spriteNum).locV + 200
          end
          The above moves the sprite's horizonal and veritical position by 200 pixels so it
          will move 200 to the right and 200 down.
          > also just pops.
          > sense
          Actually, reading the above part, sound liek you may want the effect to be animated
          rather than just a hard change. If that's the case, for belnd, you could just
          create a film loop that has the animated change and then do a switch to the
          filmloop on rollover. Do you want the animated effect of the sprite moving across
          the screen as well? You could always jump to another frame where you have that set
          up. Anywya, I may have misunderstood what you've asked. Hope this has been helpful.
          If you need more info, let me know.
          regards
          Dean
          Director Lecturer / Consultant
          http://www.multimediacreative.com.au
