Hi BrendanZ,
In addition, a workaround could be done if you create a
button or link in Flash and use the following ActionScript for the
button to load the hyperlink:
on (release){
getURL("
http://www.adobe.com", "_self");
If you insert the Flash created button in PowerPoint using
the Insert Flash option, the button will now load the Adobe website
inside the same browser window.
However, if the published file is to be played locally, you
would need to read the guidelines and respect the security
restrictions for FlashPlayer 8 if you are using FlashPlayer 8 or 9
on your computer.
You can read more about the security restrictions here:
Security Changes in Flash Player 8
http://www.adobe.com/devnet/flash/articles/fplayer8_security.html
You can also read more about using the getURL method in Flash
from the link below:
getURL
http://livedocs.macromedia.com/flash/8/main/00005202.html
And if you don't have Flash and want to see this in action,
you can get a trial version of flash on the link below:
http://www.adobe.com/go/tryflash
