1 Reply Latest reply on Aug 23, 2006 3:13 AM by 2m
    Some Basic AS Q's
      hey all
      when you put a script on a frame does it run just once or if it is stopped on the frame will the script keep run over and over?
      What about on a mc will it run continously if the main timeline is paused?
      Can more than one thing have the same instance name if they are in different frames?
      I think thats all for now, thanks in advance
        • 1. Re: Some Basic AS Q's
          2m Level 2
          Though I'm not sure if I understood all of your questions correctly I'll try to answer them best I can:
          Scripts on a frame run once everytime the "playhead" of it's timeline enters the frame. It is ran again everytime the frame is enterad again - e.g. with loops or scripts ("gotoAndPlay")
          Each mc has it's own independent timeline. Stopping the main timeline (or any other) won't affect your mc's timeline and therfore the answer is: Yes it will.
          The answer to your second question is also "yes". In fact when you have an mc called "my_mc" on the stage and make a new keyframe, that is what Flash does - more or less.
          But be carefull when doing it manually, and don't do it if not neccessary.
