• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
foreach alternative
New Here ,
Jul 27, 2006 Jul 27, 2006
I have a script written in php and an trying to find the alternative in coldfusion and don't seem to be getting anywhere, I have googled and googled, it may just be I am looking in the wrong place. Your help in greatly welcomed!
THis is the php version
$product_options=$row["product_options"];
$product_options=split(",",$product_options);
foreach($product_options as $assign_id)
//get info
$result=mysql_query("SELECT *FROM options_bot WHERE assign_id='$assign_id'");
while($row=mysql_fetch_array($result))
$option_id=$row["option_id"];
$value_id=$row["value_id"];
$option_price=$row["option_price"];
$option_symbol=$row["option_symbol"];
if($option_symbol=="+")
$opt_price=$opt_price+$option_price;
if($option_symbol=="-")
//find the name of options and values
//get the name of the option
$result=mysql_query("SELECT * FROM options_top WHERE option_id='$option_id'");
$option_name=$row["option_name"];
//get the name of the value
$result=mysql_query("SELECT * FROM options_mid WHERE value_id='$value_id'");
$value_name=$row["value_name"];
echo"<b>$option_name : </b>$value_name<br>";
$options=array($option_name,$value_name);
Here is what I have no far in Coldfusion
<cfset product_options=#product_options#>
<cfset assign_id=ListToArray(#product_options#, ",")>
<cfdump var="#assign_id#">
<cfquery name="optinfo" datasource="mydatabase">
SELECT * FROM options_bot WHERE assign_id='#assign_id#'
</cfquery>
I get this error message
Complex object types cannot be converted to simple values.
THank You Sooooo Much!
TOPICS
Advanced techniques
Views
634
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
To be fair, your PHP code is looping over an array and using the values
in each element of the array. On the other hand your ColdFusion code is
trying use the entire array object (a complex variable) in a place that
needs a single simple value (a simple variable).
To match the PHP code you need to add a loop over the array.
<cfloop from="1" to="#arrayLen(assign_id)#" index="row"
SELECT * FROM options_bot WHERE assign_id='#assign_id[row]#'
</cfquery>
</cfloop>
Votes
Translate
Translate
Report
Report
LEGEND ,
It looks like you are starting with a list and, at the end of the day, your php code is looping though the list and running a query each time.
If all you want to do is query your db for items that match any of your list items, why don't you just use the list in your query and forget all that unnecessary complicated code. Also, make sure you change your query so that it expects a list and not a single value.
Votes
Translate
Translate
Report
Report
New Here ,
I think I follow but don't fully understand, I don't expect you guys to write the code for me, but if you could give me a little harder push in the right direction. thank you so very much!
Votes
Translate
Translate
Report
Report
Engaged ,
idiaz06 what Ian Skinner showed you you is the way to do it!
the PHP split() function turns a list into an array, to loop through the array using tags you do exactly what Ian showed you, if you are more comfortable with cfscript then do the following:-
Votes
Translate
Translate
Report
Report
LEGEND ,
quote:
If you have this list:
1,2,3,4,5,7,14,89
and you want to know how many records in a table (call it myTable) where a numeric field (call it theField) matches any number in that list, do you know how to do it?
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
I will try this as soon as I can, thank you guys very much and I will come back and help when I know the answer to some ones question.
Votes
Translate
Translate
Report
Report
LEGEND ,
It depends on what your ultimate goal is.
If you just want to use a list of values as part of a where clause you
can do something like this.
WHERE assign_id IN (<cfqueryparam value="#product_options#" list="yes"
cfsqltype="cf_sql_varchar">)
If you want to run a different query for each item in the list, you can
loop over the list without turning it into an array.
<cfloop list="product_options" index="option">
SELECT * FROM options_bot WHERE assign_id='#option#'
</cfquery>
DO STUFF WITH optinfo QUERY
</cfloop>
Also, this line makes very little sense to me. Without some kind of
scoping on one side or the other, you are just setting a variable to its
current value?
Votes
Translate
Translate
Report
Report
Resources
Documentation
