5 Replies Latest reply on Jul 26, 2006 2:12 AM by annabannana
    CFHTTP
    annabannana Level 1
      Hi all,
      OK i have found loads of people having this same problem however i am unable to find a solution that works for me.
      The issue is that i need to access a third party service which sits on a 128 bit encrypted machine and everytime i hit the URL i get the words "CONNECTION FAILURE" even though i can put the URL into the browser and view the XML as i need to.
      It is fine when i put the url http://myurl.com but the issues is simply around https://myurl.com
      Surley somebody has come across this or there is a patch available or on the way????
      I found this link on the web but it did NOT work as i hoped it might - ( http://www.talkingtree.com/blog/index.cfm?mode=entry&entry=25AA75A4-45A6-2844-7CA3EECD842D B576 )
      So when i try to run the keytool to import the cert you get the error not an x.509 cert..
      This seems to be around for years - why is this?
      All help very much appreciated!
        • 1. Re: CFHTTP
          mrampson Level 1
          What version of coldfusion? cfmx7 has better support for certificates and certifcate chains. I believe there are problems with certificate chaining in cfmx6. Not sure about 6.1.
          • 2. Re: CFHTTP
            annabannana Level 1
            quote:
            Yep i am using Version 7.0 (Version: 7,0,0,91690 to be exact)
            Should have mentioned it.
            Also working from windows machine...
            • 3. Re: CFHTTP
              jdeline Level 1
              It may be rejecting the connection because it doesn't see a user agent. You can use CFHTTPPARAM to add
              "Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.0)"
              to your CFHTTP request.
              • 4. Re: CFHTTP
                jdeline Level 1
                • 5. Re: CFHTTP
                  annabannana Level 1
                  no this in not the issue - it is got to do with the fact that their server is 128 bit encry[ted and i was told that 56 bit is that max cfhttp can post to - is that true?
