1 Reply Latest reply on Jul 27, 2006 2:53 PM by mike2281
    Flex File Size
    mike2281 Level 1
      I am working on a strategy for managing and delivering a large application as a series of smaller application that load and cache on demand. Most of the architectural issues have been solved and I am starting to experiment with controlling the individual application file size.
      The first observation looking at the projects resources and reading the docs is that each app merges in the parts of the mx library and custom components that it needs. I understand the reasons behind this but the shared parts of the mx library and custom components are essentially loaded twice as they are embedded in each application.
      I understand that I can control the duplication of the custom components by placing them in a library and linking via RSL, but what about the duplicated mx components, I understand that all apps may not use exactly the same manifest of components but in this app there is a lot of duplication as each app uses many of the same mx components.
      I have not experimented with changing the linking on the mx components and do not know if it’s even possible.
      What is a good strategy for loading the a subset of the mx components only once and decreasing the individual app size?
      Mike
        • 1. Re: Flex File Size
          mike2281 Level 1
          I guess I am missing something, the main flex library is just over 1 meg, if you add in charting it’s close to 2 megs.
          When you create a project and start adding applications to it even small ones are around 200 – 400 K each and they seem to each contain copies of the dependencies, so it appears that each app in the project contains merged code, the needed parts of the flex framework.
          So in a medium size app why not load / cache the framework libraries once and have apps that range from 10 – 20 K.
          In a project you would normally have a main app that is a loader for the child apps, so the child apps don’t need to contain the dependencies already loaded when the main app loads, however based on the file size it appears that each app contains it’s own copy of the parts of the framework it needs.
          So even better would be a way to have flex know that a main app will always be loaded first so it does not embed identical resources into each child app.
          What am I missing here?
