5 Replies Latest reply on Jul 25, 2006 5:29 AM by JustStupid
    Easy method call problem
    JustStupid
      Does anyone know how to call a certain method in a parent script from a behaviour script? Have a method called startit but when it I compile it says its the handler is not found.
      Cheers,
      Brenden
        • 1. Re: Easy method call problem
          Level 7
          Have you instantiated the object? If so, where is it stored. If it's
          stored in a global variable you can call the method using dot syntax
          globalVariableName.startit ()
          If you store it in a sprite's behavior's property it could be called this
          way from outside of that behavior
          sprite (someSpriteNumber).somePropertyName.startit ()
          There are various other ways but most Lingo user's I know store a child
          object in a global variable.
          Craig Wollman
          Word of Mouth Productions
          phone 212 928 9581
          fax 212 928 9582
          159-00 Riverside Drive West #5H-70
          NY, NY 10032
          www.wordofmouthpros.com
          "JustStupid" <webforumsuser@macromedia.com> wrote in message
          news:ea4o9p$fp5$1@forums.macromedia.com...
          > Hi,
          > says
          > Cheers,
          > Brenden
          • 2. Re: Easy method call problem
            JustStupid Level 1
            Hi Craig,
            Thanks for the quick reply, yeah I think I have set the object (sorry to sound
            so dumb but just getting to grip with director). I have used the following code:
            Global beginConn
            beginConn = new(member("beginscript").script)
            beginConn.startit()
            The method I want to access:
            on startit me
            checker = timeout("looker").new(10000, #looker, me)
            end
            Which seems to work however I converted the handler script to a parent script from a movie script, to try and solve the problem of calling instances of its self (me) on the timeout script. As the target instance is not being found now even if I have converted to a parent script. Seems very strange!
            • 3. Re: Easy method call problem
              Lukewig Level 1
              A more common way of doing this is with this syntax:
              beginConn = script("beginscript").new()
              An object is an object regardless of the script type that made it (the reason why behaviours and parent scripts are generally better suited for making objects is that they have a 'protect scope' - if you call a handler without specifying the 'object' with that handler, then Director looks in all movie scripts for that handler; it wont attempt to call the handler or method defined in a parent script or behaviour unless you specify that script or an instance of that script ).
              > beginConn.startit()
              > on startit me
              > end
              Assuming 'beginConn' contains a reference to an instance of the script containing the 'startit' method, then your code looks fine (unless you are using DirectorMX2004, in which case it should be checker = timeout().new("looker", 10000, #looker, me)).
              Put a debug line in just before you create the timeout, and see what 'me' points to. eg.
              on startit me
              put "#startIt message received by " & me
              end
              on looker (me, timeoutObject)
              put "#looker message sent by " & timeoutObject & " was received by " & me
              end
              -- Luke
              • 4. Re: Easy method call problem
                JustStupid Level 1
                Thanks Luke. I will try that out. Didn't know the sytnax for creating a timeout object was different for mx 2004 either. hehe
                • 5. Re: Easy method call problem
                  JustStupid Level 1
                  Wicked worked first time! All that time spend and solved so quickly.
