Hi Jim
Yeah, sometimes the Preview window likes to perform a
pisadeering act for us!
You might give the following steps a try:
1. Close RoboHelp HTML.
You need to do this because the values we are about to change
will be destructively changed once we close RoboHelp HTML and
restart.
2. Open the Windows Registry Editor.
(All standard disclaimers apply. Back up the registry,
sacrifice a chicken, yadda yadda yadda)
3. Locate the following key:
HKEY_CURRENT_USER\Software\version\RoboHTML\version\MontereyFrame\
4. Double click the item labeled Preview in separate window
and ensure the value is set to 1. If it already is, terrific. If
not, change it to 1 and click the OK button. It doesn't matter if
the option is set to Hex or Decimal.
5. Double click the item labeled PreviewMaximized and ensure
the value is set to 0. If it already is, terrific. If not, change
it to 0 and click the OK button. It doesn't matter if the option is
6. Double click the item labeled PreviewWindowCX. Make sure
the option is set to Decimal and set the value to 50. Then click
the OK button.
7. Double click the item labeled PreviewWindowCY. Make sure
the OK button.
8. Double click the item labeled PreviewWindowX. Make sure
the OK button.
9. Double click the item labeled PreviewWindowY. Make sure
the OK button.
10. Close the Windows Registry Editor.
11. Restart RoboHelp HTML and preview a topic.
The window should now be floating above the RoboHelp HTML
application in full view.
Hopefully this helps... Rick
