2 Replies Latest reply on Sep 17, 2006 8:14 PM by anthryan
    Flash pop up window
    Sullan_1981 Level 1
      Hi all,
      How do i make a flash pop up window, with cutomised close button, which opens itself in a new window and not inside the IE window. Any idea how to do it in flash without the use of any java script. Please help.....
      Thanks in advance
      Sullan
        • 1. Re: Flash pop up window
          Level 7
          Create a MovieClip for the window. Add the close button in it and your
          assets as needed.
          Have its depth above all other content.
          Use the _visible property to open and close.
          You can get fancy with drag the window. In this case you add an internal
          MovieClip to the popup that is a drag bar and add the code when you press
          and release and releaseOutside the drag bar movie clip to start and stop
          drag on the parent movieclip.
          An another alternative is to use the Alert Component:
          http://livedocs.macromedia.com/flash/8/main/00003096.html
          Lon Hosford
          www.lonhosford.com
          Flash, Actionscript and Flash Media Server examples:
          http://flashexamples.hosfordusa.com
          May many happy bits flow your way!
          "Sullan_1981" <webforumsuser@macromedia.com> wrote in message
          news:ea9hm5$hjr$1@forums.macromedia.com...
          > Hi all,
          > button,
          > how
          > Thanks in advance
          > Sullan
          • 2. Re: Flash pop up window
            anthryan Level 1
            Lon, I'm looking for an example of what you discribed. If you have any off top, let me know. I am searching the site in your sig right now. Thanks in advanced.
