2 Replies Latest reply on Jul 25, 2006 11:41 AM by seasparrow
    How to get a Flash site higher on Google Ranking
    RockyJM
      Google (and some other search engines have problems crawling a flash site to obtain a search engine relavence ranking. Anyone have a good way around this?
        • 1. Re: How to get a Flash site higher on Google Ranking
          Pete_Hughes Level 1
          That's a tough one. Supposedly the engines can look at text inside SWFs but that's all a jumble, could be something bad through ActionScript as far as they know, and there is no way to use the tried and true HTML tag rules. Metadata is, I understand, pretty much ignored nowadays (thanks spammers!). Your best bet is some plain ole HTML text and solid incoming links. If someone knows better let them speak.
          • 2. Re: How to get a Flash site higher on Google Ranking
            seasparrow
            You could set up your flash site inside hidden frames. One frame can contain hidden html w/ meta data, H tags, etc. And the other frame has your visible swf. This is also a good set up if you want to embed a statistics rendering engine behind the scenes. Unfortunately, nothing beats standards-based html sites for search engines though, A?!
