There is some confusion all round on this thread with talk of
profiles, projects and now the application itself being located on
a network.
Anne is quite correct to point out that projects should not
be on a network. RH is based on an Access database and they are
notorious for problems on a network. Adobe themselves advise you
not to do that but of course if your System Administrator knows
better...
Roaming profiles are stored on a server but you will still
only be able to use RH on the PC on which it was installed. Other
profiles are stored on the hard disk of the user's PC.
As to installing RH on a server, that is in breach of the
licence so perhaps that will persuade your System Administrator to
install the application on your PC.
What you MUST have is RH installed on your PC using your
logon for the installation and it must have admin rights at the
time. See the topic on my site about installation.
If you need to come back, please clarify what is on the
network, your profile, your project or the application.
