14 Replies Latest reply on Jul 25, 2006 3:42 PM by Newsgroup_User
    Dropdown Menus
    Big_Foote
      I'm using Dreamweaver and Fireworks 8. I've designed my site with, slices, links and everything. Put it into Dreamweaver, no problems. Now I am changing one of the buttons to a dropdown menu. I go to the table in Dreamweaver to edit it in Fireworks. I change the button in Fireworks, everything is fine. Then hit the Done button. In Dreamweaver, after saving the template update, I can go to any page and the dropdown menu is not a dropdown menu. The dropdown list is on the bottom of the page as simple links, no dropdown attributes. It should be a dropdown from the Options button. Any suggestions? You can see the results at http://greatbuywebhosting.com/AlienAuto/index.htm
        • 1. Re: Dropdown Menus
          Level 7
          You have to add the drop down menu to the page in Dreamweaver BEFORE
          converting the page to a template.
          Linda Rathgeber [PVII] **Adobe Community Expert-Fireworks**
          http://www.projectseven.com
          Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
          CSS Newsgroup: news://forums.projectseven.com/css/
          Design Aid Kits: http://www.webdevbiz.com/pwf/index.cfm
          • 2. Re: Dropdown Menus
            Big_Foote Level 1
            Boy, what a weird way for that to work, but it does work. Infact you can make changes to the button after turning it to a template with no problem. Go figure?
            Thank you for your help, Linda.
            • 3. Re: Dropdown Menus
              Level 7
              There are quite a few things wrong with those FW menus, though. You should
              really consider more effective and efficient methods. Is it too late for
              you?
              Murray --- ICQ 71997575
              (If you *MUST* email me, don't LAUGH when you do so!)
              http://www.dreamweavermx-templates.com - Template Triage!
              http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
              http://www.dwfaq.com - DW FAQs, Tutorials & Resources
              http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
              "Big_Foote" <webforumsuser@macromedia.com> wrote in message
              news:e9rpem$1f$1@forums.macromedia.com...
              > Go figure?
              • 4. Re: Dropdown Menus
                Level 7
                "Murray *ACE*" <forums@HAHAgreat-web-sights.com> wrote in message
                news:e9s0qm$7jg$1@forums.macromedia.com...
                > should really consider more effective and efficient methods. Is it too
                > late for you?
                Murray, you are a crusader, an absolute crusader. 8^D
                Is it too late for you?
                Take care,
                Tony
                • 5. Re: Dropdown Menus
                  Big_Foote Level 1
                  No, it not too late to change. After all, this was a test to see how DW and FW work together. I always like to try new things. Unfortunitately this is not working out the way I had expected. It should work with the template and one of the bugs of FW.
                  I will do some more experimenting.
                  • 6. Re: Dropdown Menus
                    Level 7
                    > the bugs of FW.
                    It's not a bug. You have to thoroughly understand the way Dreamweaver
                    templates work, and the way that Fireworks and Dreamweaver interact,
                    before you use them together in that way.
                    • 7. Re: Dropdown Menus
                      Sw Jiten Level 1
                      Dear Murray, what is/are the best practice in this case, according to you ? Thanx in advance..
                      • 8. Re: Dropdown Menus
                        Level 7
                        Check the uberlink and McFly tutorials at PVII
                        ( http://www.projectseven.com/)
                        and the Navbar tutorial at Thierry's place ( http://www.tjkdesign.com)
                        Or to get it done fast, go here -
                        http://www.projectseven.com/tutorials/navigation/auto_hide/index.htm
                        It is best practice never to use an all javscript menu like DW and FW<8
                        produce, and the new ones that FW8 does are hardly better, although not
                        suffering from all the maladies of the previous version.
                        "Sw Jiten" <webforumsuser@macromedia.com> wrote in message
                        news:e9sm4u$1u3$1@forums.macromedia.com...
                        • 9. Re: Dropdown Menus
                          Level 7
                          I went to the list of complete tutorials and I couldn't find McFly . . .
                          then discovered it's MacFly.
                          Tony
                          • 10. Re: Dropdown Menus
                            JLSF Level 1
                            So, I was reading some of the posts about drop down menus in Fireworks. I have the same problem - I made some drop down menus in Fireworks, exported the file and it works fine - for that one file alone.
                            If you save a version of it to another folder they TRY to work, but things get all gobbly; paths don't work, background colors disappear, etc. In subordinated or copies of the page I tried re-setting the path to the generated mm_menu.js, but that doesn't work either.
                            Is there no way around this from Fireworks? I just already put a lot of time into that file.
                            Many thanks.
                            • 11. Re: Dropdown Menus
                              Level 7
                              > into that file.
                              Complain to Adobe. They have cost you time and money.
                              Run away from this mess while you still have your sanity!
                              "JLSF" <webforumsuser@macromedia.com> wrote in message
                              news:ea3fn1$17u$1@forums.macromedia.com...
                              > have
                              > file
                              > get
                              > subordinated
                              > mm_menu.js,
                              > time
                              > into that file.
                              > Many thanks.
                              • 12. Re: Dropdown Menus
                                Level 7
                                Thanks, Tony! I've reprogrammed the 'bot'.
                                "Anthony Bollinger" <tonyb2006@NEVERsendto.org> wrote in message
                                news:ea36u7$ke1$1@forums.macromedia.com...
                                > Tony
                                • 13. Re: Dropdown Menus
                                  JLSF Level 1
                                  LOL....Oh, woe is me. But I appreciate the humor. Very well then; off to write it myself. One quick Q; the powers that be must know about this issue. Anyone know of attempts being made to remedy the problem?
                                  Again, many thanks for the quick response and the assistance.
                                  j
                                  • 14. Re: Dropdown Menus
                                    Level 7
                                    > Anyone
                                    Considering that half of the regular community has been on them since DW4 to
                                    do so, one would hope....
                                    news:ea6077$4jk$1@forums.macromedia.com...
                                    > write
                                    > Anyone
                                    > j
