3 Replies Latest reply on Jul 27, 2006 5:31 PM by Boerboel649
    email?
    design_times
      i've created a button that should open an email window when pressed. i found some code... but it doesn't seem to work.
      contactHotspot_mc.onRelease = function(){
      getURL("mailto:inquiries@alamorganart.com");
      could someone point me in the right dirction?
      thanks in advance for any help!
        • 1. Re: email?
          Level 7
          That should work. Where are you putting this code? On the main timeline?
          What is the instance name of your button?
          Dan Mode
          *THE online Radio* http://www.tornadostream.com
          *Must Read* http://www.smithmediafusion.com/blog
          *Flash Helps* http://www.smithmediafusion.com/blog/?cat=11
          "design_times" <webforumsuser@macromedia.com> wrote in message
          news:ea8sm5$oog$1@forums.macromedia.com...
          > found
          • 2. Re: email?
            design_times Level 1
            i thought so too... the code is on the main timeline and the instance name is contactHotspot_mc. basically... i typed the word contact, turned it into a mc (contactPulse_mc) so that i could put a mouseover effect on it and then made the hot spot the functioning button. here's the full block of code for the contact button.
            contactHotspot_mc.onRollOver = function(){
            contactPulse_mc.gotoAndPlay(2);
            contactHotspot_mc.onRollOut = function(){
            contactPulse_mc.gotoAndStop(1);
            when i test it, the mouse over effects work fine but it does nothing when pressed. i'm so lost!!!
            • 3. Re: email?
              Boerboel649
              Well, you could put this code in the button itself...
              on (release) {
              getURL("mailto:youremail@yourhost.com")
