10 Replies Latest reply on Aug 25, 2006 4:35 PM by Newsgroup_User
    Phone Number Vaildation
    burritobot Level 1
      Anyone have a function that checks for phone number input errors?
      Something like:
        • 1. Re: Phone Number Vaildation
          Level 7
          burritobot,
          I don't know about "have a function," but I'll be happy to help you
          write a function -- that's even better, because once you know how, you'll be
          able to use your skill again for other purposes in the future. :)
          > If (number is less or more than 10 digits){
          > giveError();
          It's easiest with numbers, I think -- but before we begin ... is the
          phone number, as entered by the user, a number, or a string? If it has
          numerals only, it might be a number. If not -- if, for instance, it also
          includes hyphens or other characters -- it would be a string and would have
          to be converted. Have you gotten this far yet, or would we have to start
          from here?
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: Phone Number Vaildation
            Level 7
            i would try with something like this
            // first of all, you have to be sure that there are only numbers in the
            variable, thats easy:
            name_of_the_variable.restrict = "0-9";
            // the only things that you can insert are numbers from 0 to 9
            // then you have the IF statement:
            if (name_of_the_variable.length == 10 && name_of_the_variable.substr(0, 1)
            != "0" && name_of_the_variable.substr(0, 1) != "1") {
            trace("ok");
            } else {
            trace("noooop");
            you can see that you have an IF with 3 conditions, and because the operators
            are AND (&&) the 3 have to be true
            - name_of_the_variable.length == 10 //// number is less or more than 10
            digits
            - name_of_the_variable.substr(0, 1) != "0" //// you select the first
            number and check that this number is not (!=) 0
            - name_of_the_variable.substr(0, 1) != "1" //// you select the first
            number and check that this number is not (!=) 1
            there are many ways to do it (as much as programers)
            i hope this help you, and that you can learn how to think it
            "burritobot" <webforumsuser@macromedia.com> escribi� en el mensaje
            news:ebvsud$ms5$1@forums.macromedia.com...
            > Something like:
            > giveError();
            > } else if (number contains erroneous characters){
            > give Error();
            > }else if (number starts with 0 or 1){
            > give Error();
            • 3. Re: Phone Number Vaildation
              Level 7
              > numbers in the variable, thats easy:
              This is a good idea. This restricts text entry into TextField,
              TextArea, and TextInput instances. Unfortunately, the OP didn't mention
              anything about *how* this information is being gathered -- perhaps from some
              external source (PHP, etc.)? -- so it may be moot. But good thinking.
              I'm surprised he or she hasn't come back.
              David Stiller
              • 4. Re: Phone Number Vaildation
                Level 7
                david,
                i really liked your blog
                i'll be glad (if you want) to contribute to it in what i can
                regards
                Juan Ignacio Caffini
                www.caffini.com.ar
                "David Stiller" <stiller-NO-SPAM-@quip.net> escribi� en el mensaje
                news:ecl3lq$7u0$1@forums.macromedia.com...
                > some external source (PHP, etc.)? -- so it may be moot. But good
                > thinking.
                > David Stiller
                • 5. Re: Phone Number Vaildation
                  Level 7
                  Juan,
                  Thanks!
                  WordPress does allow for multiple authors, but I hadn't given it much
                  thought. For the time being, I'm comfortable being the sole author, but I'm
                  always happy to see comments.
                  I think your http://www.mocean.tv/ interface is terrific! Reminds me of
                  old Myst or some of the later Zork entries. Beautiful artwork!
                  David Stiller
                  • 6. Re: Phone Number Vaildation
                    Level 7
                    Juan,
                    Thanks!
                    David Stiller
                    • 7. Re: Phone Number Vaildation
                      Level 7
                      Juan,
                      Thanks!
                      David Stiller
                      • 8. Re: Phone Number Vaildation
                        Level 7
                        Juan,
                        Thanks!
                        David Stiller
                        • 9. Re: Phone Number Vaildation
                          Level 7
                          Juan,
                          Thanks!
                          David Stiller
                          • 10. Re: Phone Number Vaildation
                            Level 7
                            Juan,
                            Thanks!
                            David Stiller
