0 Replies Latest reply on Jan 8, 2009 2:54 AM by testuserPankaj
    Problem in audio conferencing using Flex and FMS3.0
    testuserPankaj
      Hi Everyone,
      I am trying to achieve audio conferencing using Flex and FMS3.0
      Currently I am following an approach where all the persons in voice conference publish their voice on flash media server using NetStream.Publish() function and all persons listen to the streams published by all other members in the conference using NetStream.Play() function. I am using a shared array on server side to keep track of all the persons present in the conference. The problem I am facing is that sometimes all the persons are able to hear the voice of each other but other times audio of some persons is not audible to others. Even if voice comes then there is echo and one can hear the sound 3-4 times depending on the amplitude of the sound. I have also used Microphone.setUseEchoSuppression(true) to suppress the echo but it is not effectively suppressing it. If someone has faced similar problems in past please let me know the solution. Thanks in advance.
      Regards,
      Pankaj
