6 Replies Latest reply on Jan 27, 2010 11:32 AM by pradeep gorijavolu
    Workspace Crashes
    Level 7
      I am getting repeated workspace crashes when starting Flex Builder 2
      (final). I have isolated the problem an SWFLoader of a SWF file.
      Here is the contents of the error log:
      !SESSION 2006-07-25
      14:48:07.671 -----------------------------------------------
      eclipse.buildId=unknown
      java.version=1.4.2_09
      java.vendor=Sun Microsystems Inc.
      BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
      Command-line arguments: -os win32 -ws win32 -arch x86
      !ENTRY org.eclipse.core.resources 2 10035 2006-07-25 14:48:08.921
      !MESSAGE A workspace crash was detected. The previous session did not exit
      normally.
      !SESSION 2006-07-25
      14:49:59.546 -----------------------------------------------
      !ENTRY org.eclipse.core.resources 2 10035 2006-07-25 14:50:00.656
      normally.
      !SESSION 2006-07-25
      14:50:49.296 -----------------------------------------------
      !ENTRY org.eclipse.core.resources 2 10035 2006-07-25 14:50:50.406
      normally.
        • 1. Re: Workspace Crashes
          Level 7
          Here is what the pop-up gives when the error occurs (you guys should also
          make this a paste-able block).
          JVM Terminated. Exit code=1
          C:\Program Files\Adobe\Flex Builder 2\jre\bin\javaw.exe
          -Xms128M
          -Xms512M
          -XX:MinHeapFreeRatio=20
          -jar C:\Program Files\Adobe\Flex Builder 2\startup.jar
          -os win32
          -ws win32
          -arch x86
          -launcher C:\Program Files\Adobe\Flex Builder 2\FlexBuilder.exe
          -name FlexBuilder
          -showsplash 600
          -exitdata 188c_6c
          -vm C:\Program Files\Adobe\Flex Builder 2\jre\bin\javaw.exe
          -vmargs
          -Xms128M
          -Xms512M
          (I was able to isolate this to one component, which repeatedly crashes
          FlexBuilder).
          • 2. Re: Workspace Crashes
            njadobe Level 1
            Hi Yechezkal,
            Exactly when does the crash occur? Does it happen when you open the custom component, or when you open a file that uses the component? Also, does it happen when you're in code view, or only in design view?
            Would it be possible for you to post the source of the custom component? That would help us track down the crash. (If you don't want to post it publicly, we could arrange for you to email it to us directly.)
            nj
            Flex Builder team
            • 3. Re: Workspace Crashes
              njadobe Level 1
              Also--the SWF file that the SWFLoader is trying to load may be causing the problem. It would be great if you could post that somewhere we could get to it as well.
              nj
              • 4. Re: Workspace Crashes
                Level 7
                In answer to your questions:
                1. The crash only occurs when I change the view on the MXML to "Design
                Mode". But once I do that, Design mode is sticky and it sticks to the last
                open file. So each time I restart FlexBuilder2 I get the crash. So it is a
                major pain.
                2. As I said, I isolated things to this very short custom component. Which
                only contains an SWFLoader. If I commment out the loading of this component
                (Which I have to do outside of FlexBuilder2 with a text editor) then I can
                restart FB2.
                <mx:Box xmlns:mx=" http://www.adobe.com/2006/mxml" xmlns:local="*"
                creationComplete="startup()">
                <!-- Load the Flash 8 Yahoo map movie-->
                <local:MapTalk id="mapTalk" />
                <mx:SWFLoader id="map" width="100%" height="100%"
                source="flashMap.swf" autoLoad="true"
                x="1" y="1" scaleContent="true"/>
                <mx:Script>
                <![CDATA[
                [Inspectable(defaultValue="flashMap.swf")]
                public var mapMovie:String = "file:///C|/FlexWork/flex maps/flashMap.swf";
                private function startup():void {
                trace("flash component created");
                public function setLocation(address:String):void {
                trace("setting location to: " + address);
                mapTalk.addMarker(address);
                </mx:Script>
                </mx:Box>
                3. I can provide for you the SWF. But basically, it is the Yahoo Maps SWC
                component wrapped in a very light weight wrapper. see
                http://www.asfusion.com/blog/entry/inserting-yahoo-maps-in-a-flex-2-application
                If you give me an email address, I will send you all my sources (no problem
                with that).
                4. The odd thing about this is, the current sequence that I use (only doing
                thing in MXML (not design mode) and then compiling the item - Allows this
                file to work. From then on, I seem to be able even to use Design Mode. It
                seems to be some sort of race condition with doing the first compile from
                Design Mode. (probably if it was not an autoload this would work. But even
                if I can hack around this, this is probably something you guys want to look
                into. It should not be possible to crash FB2 over and over).
                Dr. Y Gutfreund (Adobe Community Expert - Mobile Devices).
                • 5. Re: Workspace Crashes
                  RemsX
                  I'm having a similar problem (I'm on Mac OS 10.6 though).
                  It seems that for some reason design view will cause the program to crash.  I should mention that I imported a project I started using the Flash Catalyst Beta2, which might have something to do w/ it.  Not sure...  Iknow this is vague, sorry.
                  • 6. Re: Workspace Crashes
                    pradeep gorijavolu
                    For me also same problem happens what ever discussed
                    in the forum........
                    for me it is getting crashed regularly like per day i restarted the flexbuilder minimum 20 to 25 times
                    please let me know the solution asap.......
                    Regards,
                    Pradeep
