4 Replies Latest reply on Aug 3, 2006 10:37 AM by knot_sofast
    FDS Instantiation Error
    knot_sofast
      Background: I tried to mimic the ‘contact’ Data Service example but can’t get my destination to instantiate on the server. I was able to get the contact sample working but my customized version is dead in the water.
      The error looks like this when I start up the JRUN server:
      At jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
      [0]flex.messaging.config.ConfigurationException: Unable to create service’flex.data.DataService’ for ‘data-service’ due to the following error: Error instantiating application scoped instance of type ‘samples.twa.TwaAssembler’ for destination ‘person’..
      1)How can I find out why the destination ‘person’ couldn’t be instantiated by the Data Service?
      2)Do the class files need to be put into an archive file? If so where should put the archive file so that the server will see it?
      3) Did I miss something else?
      The process that I followed is listed below:
      1) I added the following to samples\WEB-INF\flex\data-management-services.xml:
      <destination id="person">
      <adapter ref="java-dao" />
      - <properties>
      <source>samples.twa.TwaAssembler</source>
      <scope>application</scope>
      - <metadata>
      <identity property="personId" />
      </metadata>
      - <network>
      <session-timeout>20</session-timeout>
      <paging enabled="false" pageSize="10" />
      <throttle-inbound policy="ERROR" max-frequency="500" />
      <throttle-outbound policy="REPLACE" max-frequency="500" />
      </network>
      - <server>
      - <fill-method>
      <name>loadPersons</name>
      </fill-method>
      - <fill-method>
      <params>java.lang.String</params>
      </fill-method>
      - <sync-method>
      <name>syncPersons</name>
      </sync-method>
      </server>
      </properties>
      </destination>
      2. I created TwaAssembler.class , Person.class, PersonDAO.class, DAOException.class ConnectionHelper.class, ConcurrencyException.class, and ValidationException.class and put them in the samples\WEB-INF\classes\samples\twa folder.
      3. I created a Person.as file and put in the samples\twa\samples\twa folder and I also put it in the samples\dataservice\twa\samples\twa folder.
      4. I created a Flex twa.mxml file that defines the Binding of a Grid object to the Data Service.
      <?xml version="1.0" encoding="utf-8" ?>
      - <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" creationComplete="initApp();">
      - <mx:Script>
      - <![CDATA[
      import mx.data.DataService;
      import mx.collections.ArrayCollection;
      import samples.twa.Person;
      public var ds:DataService;
      [Bindable]
      public var persons:ArrayCollection;
      public var person:Person;
      public function initApp():void {
      persons = new ArrayCollection();
      ds = new DataService("person");
      ds.fill(persons);
      </mx:Script>
      - <mx:DataGrid id="dg" dataProvider="{persons}" editable="true">
      - <mx:columns>
      <mx:DataGridColumn dataField="PersonId" headerText="Id" editable="false" /> etc...
      5. I created a hsqldb ‘twa’ database with a ‘Person’ table for the java-dao to query and put it in the samples\WEB-INF\db\twa folder.
        • 1. Re: FDS Instantiation Error
          sanclementetech Level 1
          Your process "looks" correct.
          I assume your package header for your java classes is
          [code]package samples.twa;[/code]
          Also have you written a java test class that excercises your java code to make sure that is working properly? Sorry - have to ask!
          • 2. Re: FDS Instantiation Error
            knot_sofast Level 1
            First of all - Thank you for responding to my post!
            yes the package header is package samples.twa;
            I have not written a test class for the java code yet. I will do that and update my post.
            Again thank you for your response!
            • 3. Re: FDS Instantiation Error
              knot_sofast Level 1
              I created a test program for Java code and it successfully calls the loadPersons method. I copied the class files from this test program's build\classes directory to classes\twa directory and tried unsuccessfully to start Data Service destination person.
              I am building my java code in NetBeans 5.0 . Is there a certain type of project template that needs to be used to make the class files executalbe by the Data Service thread. I noticed that in the contact example's ContactAssembler class that there is no main and no constructor for ContactAssembler
              Should I be putting these classes in a jar file? If yes what file do I modify to add the jar file to the class-path of the Data Service thread?
              • 4. Re: FDS Instantiation Error
                knot_sofast Level 1
                I finally got my application to run! The problem was that I had been compiling the Java classes as a General Application using NetBeans 5. When I switched over to a Web Application Project the classes were executable/callable by the Data Service thread.
