1 Reply Latest reply on Jul 26, 2006 2:44 AM by SallyZhao
    Can't remove a node from a tree
    SallyZhao
      I am using the custom tree dataDescriptor provided in Flex live doc. It works for creating the tree and add notes, however when I try to remove a node from the tree it cant work. Does anyone have any idea?
      This is the code for MyCustomeTreeDataDescriptor.as
      package
      import mx.collections.ArrayCollection;
      import mx.collections.CursorBookmark;
      import mx.collections.ICollectionView;
      import mx.collections.IViewCursor;
      import mx.events.CollectionEvent;
      import mx.events.CollectionEventKind;
      import mx.controls.treeClasses.*;
      public class MyCustomTreeDataDescriptor implements ITreeDataDescriptor
      // The getChildren method requires the node to be an Object
      // with a children field.
      // If the field contains an ArrayCollection, it returns the field
      // Otherwise, it wraps the field in an ArrayCollection.
      public function getChildren(node:Object,
      model:Object=null):ICollectionView
      try
      if (node is Object) {
      if(node.children is ArrayCollection){
      return node.children;
      }else{
      return new ArrayCollection(node.children);
      catch (e:Error) {
      trace("[Descriptor] exception checking for getChildren");
      return null;
      // The isBranch method simply returns true if the node is an
      // Object with a children field.
      // It does not support empty branches, but does support null children
      // fields.
      public function isBranch(node:Object, model:Object=null):Boolean {
      try {
      if (node.children != null) {
      return true;
      catch (e:Error) {
      trace("[Descriptor] exception checking for isBranch");
      return false;
      // The hasChildren method Returns true if the node actually has children.
      public function hasChildren(node:Object, model:Object=null):Boolean {
      if (node == null)
      return false;
      var children:ICollectionView = getChildren(node, model);
      try {
      if (children.length > 0)
      return true;
      catch (e:Error) {
      return false;
      // The getData method simply returns the node as an Object.
      public function getData(node:Object, model:Object=null):Object {
      try {
      return node;
      catch (e:Error) {
      return null;
      // The addChildAt method does the following:
      // If the parent parameter is null or undefined, inserts
      // the child parameter as the first child of the model parameter.
      // If the parent parameter is an Object and has a children field,
      // adds the child parameter to it at the index parameter location.
      // It does not add a child to a terminal node if it does not have
      // a children field.
      public function addChildAt(parent:Object, child:Object, index:int,
      var event:CollectionEvent = new CollectionEvent(CollectionEvent.COLLECTION_CHANGE);
      event.kind = CollectionEventKind.ADD;
      event.items = [child];
      event.location = index;
      if (!parent) {
      var iterator:IViewCursor = model.createCursor();
      iterator.seek(CursorBookmark.FIRST, index);
      iterator.insert(child);
      else if (parent is Object) {
      if (parent.children != null) {
      if(parent.children is ArrayCollection) {
      parent.children.addItemAt(child, index);
      if (model){
      model.dispatchEvent(event);
      model.itemUpdated(parent);
      return true;
      else {
      parent.children.splice(index, 0, child);
      if (model)
      return true;
      return false;
      // The removeChildAt method does the following:
      // If the parent parameter is null or undefined, removes
      // the child at the specified index in the model.
      // removes the child at the index parameter location in the parent.
      public function removeChildAt(parent:Object, child:Object, index:int, model:Object=null):Boolean
      event.kind = CollectionEventKind.REMOVE;
      //handle top level where there is no parent
      if (!parent)
      iterator.remove();
      if (model)
      return true;
      if (parent.children != undefined)
      parent.children.splice(index, 1);
      if (model)
      return true;
      return false;
      This is my tree definition:
      <mx:Tree width="143" top="0" bottom="0" left="0" height="100%"
      id="publicCaseTree"
      dataDescriptor="{new MyCustomTreeDataDescriptor()}"
      dataProvider="{ac}"
      defaultLeafIcon="@Embed('assets/caseIcon.png')"
      change="publicTreeChanged(event)"
      dragEnabled="true"
      dragMoveEnabled="false"/>
      This is how I remove the selected node from the tree. When Delete button is clicked, the doDeleteCase function is exectuted.
      public function publicTreeChanged(event:Event):void {
      selectedNode = publicCaseTree.dataDescriptor.getData(Tree(event.target).selectedItem, ac);
      public function doDeleteCase(event:Event):void{
      publicCaseTree.dataDescriptor.removeChildAt(publicCaseTree.firstVisibleItem, selectedNode, 0, ac);
      Any help would be appreciated.Thanks.
