6 Replies Latest reply on Jul 25, 2006 4:18 PM by Newsgroup_User
    Get the key of an array?
    Level 7
      var myObject:Array ;
      myObject['name'] = "1";
      myObject['age'] = "2";
      myObject['sex'] = "3";
      for (var s in myObject) {
      trace ("myObject." + s + " = " + myObject[s]);
      this doesn't work...
      i want to print out "name=1", "age=2"
      thanks...
        • 1. Re: Get the key of an array?
          Level 7
          u simply forgot 3 meaningfull chars:
          var myObject:Array = [];
          now try tracing.
          eRez
          "howachen" <howachen@gmail.com> wrote in message
          news:ea50bl$otl$1@forums.macromedia.com...
          > thanks...
          • 2. Re: Get the key of an array?
            Level 7
            Then just make a change to how you trace it...
            trace ("s + " = " + myObject[s]);
            Jeckyl
            • 3. Re: Get the key of an array?
              Level 7
              well, what is the meaning of " = []; "
              in fact, without these characters, the array still work
              thanks as i am new to as...
              > now try tracing.
              > eRez
              >> thanks...
              • 4. Re: Get the key of an array?
                Level 7
                if i use the following syntax, how to do it?
                var myObject:Array = new Array();
                what is the difference?
                > Jeckyl
                • 5. Re: Get the key of an array?
                  Level 7
                  No difference
                  and
                  are identical
                  how about you actually try it , and you'd SEE that it works the same.
                  Jeckyl
                  • 6. Re: Get the key of an array?
                    Level 7
                    it is actually setting the variable ot have a n array in it .. wirthout
                    setting it = to something, the variable remains undefined and you cannot do
                    'myObject["name"] = "1"' etc.
                    no .. it won't
                    Jeckyl
