3 Replies Latest reply on Jan 15, 2009 6:12 AM by Newsgroup_User
    callLater order
    Richard_Abbott Level 3
      Hi all,
      I tend to use callLater quite a lot, usually to ensure that something has finished happening after initialising some component or other from a downloaded XML config file. Now, does callLater in any way guarantee an order of execution? I find I'm running the risk of setting off two "chains" of handlers and started to wonder if I could be sure what would happen first.
      Thanks, Richard
        • 1. Re: callLater order
          Level 7
          "Richard_Abbott" <webforumsuser@macromedia.com> wrote in message
          news:gkkaqb$5ge$1@forums.macromedia.com...
          > Hi all,
          > downloaded
          > handlers
          No.
          You should be using the invalidation functions. If you call
          invalidateProperties();
          invalidateSize();
          invalidateDisplayList();
          The functions will run this way:
          commitProperties();
          measure();
          updateDisplayList();
          If you call them like this:
          invalidateSize();
          They will still run like this:
          commitProperties();
          measure();
          And if you call them like this:
          invalidateSize();
          commitProperties();
          measure();
          That means that you can put calls in to these whenever you do something that
          means that you need to run code that you've put into your override of one of
          these functions, and you can be guaranteed that at the next invalidation
          cycle that the code will run in that order.
          HTH;
          Amy
          • 2. Re: callLater order
            Thanks Amy
            • 3. Re: callLater order
              Level 7
              news:gkmres$ik4$1@forums.macromedia.com...
              > Thanks Amy
              You're welcome. :-)
