3 Replies Latest reply on Sep 12, 2006 9:46 PM by Newsgroup_User
    Output from an Xtra
    mjacoby Level 1
      Is there a reason I would get this type of output when I call a method from an Xtra?
      <Object list 1 b846770>
      It usually returns a list of int values. . .
      Thanks in advance,
      Marc
        • 1. Re: Output from an Xtra
          Level 7
          This would most likely be because you're using Director MX2004 and you
          are calling a method in a MIAW (or otherwise using the new DOM reference
          syntax) to call a handler that returns a list (or other high-level data
          type).
          For example, syntax like the following might cause this bug:
          tList = window("name").movie.handler()
          where the #movie-script handler() returns a list.
          • 2. Re: Output from an Xtra
            mjacoby Level 1
            That's it! I am calling a method that returns a list from a MIAW.
            Thanks Sean.
            But, aside from changing the structure of this project by not using a MIAW, how can I avoid this?
            Cheers,
            Marc
            • 3. Re: Output from an Xtra
              Level 7
              Change your call from the new window().movie.handler() syntax back to
              old-school 'tell':
              tell window("name") to tList = handler()
              -- use the returned list as you desire...
