9 Replies Latest reply on Sep 11, 2006 9:45 AM by Newsgroup_User
    Simple Question
    SEPHlROTH
      Hi, I make a flash with 2 frames, I put a stop on frame 1 but I want it to jump to frame 2 after 10 second, I think that have something to do with getTimer but I never use it b4, can someone show me how to get it to work?
        • 1. Re: Simple Question
          injpix Level 3
          Just put the following on frame 1.
          • 2. Re: Simple Question
            SEPHlROTH Level 1
            Thanks man I'll try it later on.
            • 3. Re: Simple Question
              SEPHlROTH Level 1
              I'm using Flash MX now and the script didn't work, is the script for flash 8 only? can u please show me a script for MX?
              • 4. Re: Simple Question
                Level 7
                SEPHlROTH,
                > script for MX?
                Dude, you can look up the Help documentation from right inside Flash.
                It'll tell you what works for that version and what doesn't. e.g., look up
                "onEnterFrame" ... see if you find it. If you don't, you'll know your
                version of Flash is too early to support that. Look up function, look up
                Math (Math.ceil); look up getTimer(), and so on. There are only a handful
                of terms to look up. ;)
                David Stiller
                Adobe Community Expert
                Dev blog, http://www.quip.net/blog/
                "Luck is the residue of good design."
                • 5. Re: Simple Question
                  injpix Level 3
                  As Stiller mentioned use the helpdocs. I typically find my answers in the helpdocs/livedocs by simply hitting F1 (for Windows) in Flash. However after looking up all of the keywords in the code I provided it should still work for your version of Flash. Flash MX came out before my time so I am may be overlooking something here. What errors if any are you getting? What exactly is it doing or not doing?
                  • 6. Re: Simple Question
                    silvermole
                    I use MX and found that this works on the first frame:
                    stop();
                    function moveOn(){
                    gotoAndStop(2)
                    setInterval(moveOn,10000);
                    Dont forget to add a stop(); to your second frame also.
                    OK , I think he got message about the Help facilities within flash. A little help is encouraging. Besides, what are forums for
                    • 7. Re: Simple Question
                      silvermole Level 1
                      stop();
                      function moveOn(){
                      gotoAndStop(2)
                      • 8. Re: Simple Question
                        Level 7
                        > what are forums for
                        Definitely, forums are for help. :) I didn't mean to sound harsh in my
                        reply, either (I don't *think* I did, but how knows ...). I've seen other
                        entries by the same person asking the same thing: does xyz work in my
                        version of Flash?
                        The best help anyone can give, I think, is to give a person the tools he
                        or she needs to help him- or herself.
                        David Stiller
                        • 9. Re: Simple Question
                          Level 7
                          Seph - i tried that code in a new Flash document, and it works fine.
                          > > what are forums for
                          Well, really, forums are for when you've exhausted the usual methods of
                          *helping yourself*. I would include the help files and searching for an
                          answer in forums, and elsewhere (i.e. Goolge) in this category.
                          he
                          Indeed. 'Give a man a fish and he may eat for a day...' etc :)--
                          Remove '_spamkiller_' to mail
