0 Replies Latest reply on Sep 13, 2006 2:23 AM by jim_phelps
    Coding Axis - Critical Problem
    jim_phelps
      I've a critical problem when I want to code in actionscript a chart with a linearxis. Indeed, all propertie can be set but the baseAtZero doesn' t work properly. It computes the maximum value but the minimum value is always 0. I've tried with several different series without any success.
      I found the same topics on others forums but nobody can bring an answer to this problem.
      I'm blocked on this aspect.
      Is anybody has an example or guidelines (for example, this property must be set before one other etc..) to solve this problem ?
      Thank you in advance
      O.
