3 Replies Latest reply on Sep 10, 2006 10:42 AM by LeftCorner
    CFLog question
    Level 7
      I have the following code:
      <cflog text="Account edit has been made for #Session.Username#"
      file="c:\Inetpub\wwwroot\serenity\Logs\UserAccounts.log" type="information">
      But, in the requested directory, no file called UserAccounts.log is created.
      Am I missing something?
        • 1. Re: CFLog question
          LeftCorner
          <cflog> stores log files at \\CFusionMX7\logs\
          The file attribute is just the name of the log file.
          file="UserAccounts.log" type="information">
          Will create a log file at \\CFusionMX7\logs\UserAccounts.log
          You can then use CF Administrator to view the log file, or <cffile> to fetch if for your application.
          • 2. Re: CFLog question
            Level 7
            Except 1 problem. After adding that code, and running the page, I can't
            find anywhere on the HDD, a file named UserAccounts.log
            Its not in the \\cfusionMX\Logs directory, or anywhere else......
            "LeftCorner" <webforumsuser@macromedia.com> wrote in message
            news:edvl89$r5t$1@forums.macromedia.com...
            > fetch
            • 3. Re: CFLog question
              LeftCorner Level 1
              There is one problem and one potential problem.
              First is the file extension is not needed, so it should be:
              <cflog text="Account edit has been made for #Session.Username#" file="UserAccounts" type="information">
              Next is that your Session variable is not locked.
              <cflock timeout="5" type="READONLY" scope="SESSION">
              </cflock>
              However those two problems aside you should have seen a file called UserAccounts.log.log under \CFusionMX7\logs. The only thing I can think of is that the ColdFusion servce does not have write permissions to that directory, which would be strange because it writes its own log files there.
