0 Replies Latest reply: Sep 12, 2006 11:12 AM by luiz.bonfa RSS
    CairngormStore for Flex 2
    luiz.bonfa Community Member
      I am trying to run CairngormStore for Flex 2 end-to-end.
      It looks like the only deployment/configuration problem left is the configuration of Data Services.
      What is already done:
      - Flex 2 SDK is installed
      - Flex 2 builder is up and running
      - Flex 2 Data Service Express is installed with the option "JRun"
      - Cairngorm Library is installed
      - Project CairngormStore_2 is created in FlexBuilder ( Project type "Flex Data Service")
      - the path to the Cairngorm Library is defined
      - the path to the JRun is defined
      - CairngormStore is build OK
      - JRun starts successfully
      Attempt to run the CairngormStore results in run-time alert message "Products can't be retrieved".
      Obviously my deployemnt /configuration of Data Services on the client and server side is not complete.
      Given pretty involved combination of declarative configuration parameters and configuration files it is
      not easy to figure out what the problem is and how to cure it.
      Any hint, advise will be greately appreciated.
