2 Replies Latest reply on Sep 10, 2006 12:23 PM by Newsgroup_User
    Change cast member images
    Level 7
      Hello:
      I need to change images in the stage from the cast member.
      The problem is that when I change the image, the previous image on the stage
      appears and quickly the new appears.
      How can I desappear the previous image before to show the new?
      Thank you very much
        • 1. Re: Change cast member images
          Level 7
          Not understanding exactly what your are doing, one can temporarily had
          the sprite by setting the blend prop to 0 or by setting the vidoble of
          that channel to false.
          A sprite triggered by an on EnerFrame handler could switch te member
          before the score assigned mbmer makes it's initial appearance.
          • 2. Re: Change cast member images
            Level 7
            Thank you:
            The problem is that I am stopped in frame 10 for example, in this frame I
            change the cast member image by Lingo and send the head to frame 1 and the
            image that I had before I see it and then change to the new.
            "JB" <lingoguy@sbcglobal.net> escribi� en el mensaje
            news:lingoguy-3EAAE6.11375310092006@forums.macromedia.com...
