4 Replies Latest reply on Sep 15, 2006 12:57 AM by Newsgroup_User
    Rotate CastMember
    Joselito2409-i8BNIt
      How can I rotate a castmember via lingo.
      Jota
        • 1. Re: Rotate CastMember
          Level 7
          Hi Jota,
          I'm guessing that you mean rotate a sprite.
          sprite(X).rotation = 60
          will rotate sprite x to 60 degrees. The value of the rotation property
          is absolute, not cumulative. So using the line above more than once
          won't move the sprite more than 60 degrees.
          The sprites that rotate, will rotate around their registration point, so
          a toolbox sprite, if it rotated, would rotate around it's upper left
          corner. But then toolbox sprites don't have a rotation property.
          Rob
          _______
          Rob Dillon
          Adobe Community Expert
          http://www.ddg-designs.com
          412-243-9119
          http://www.macromedia.com/software/trial/
          • 2. Re: Rotate CastMember
            Scotty T.H. Level 1
            Hey Jota
            I have found that graphics you create using the Director Tools however if you are trying to rotate graphics that you have imported ... no probs.
            I was unsure if you simply wanted to set a sprite on an angle or have a sprite rotate until it reaches a particular angle.
            If this is the case try:
            -- only works while mouse is over that sprite
            on mouseWithin
            if sprite rotation < 45 then
            sprite(?).rotation = sprite(?).rotation + 1
            end
            or
            -- works when sprite is clicked on
            on mouseUp
            repeat while sprite(?).rotation < 45
            updatestage
            end repeat
            • 3. Re: Rotate CastMember
              Scotty T.H. Level 1
              oops! I meant ...
              on mouseWithin
              if sprite(?) rotation < 45 then
              end
              or
              on mouseUp
              updatestage
              end repeat
              • 4. Re: Rotate CastMember
                Level 7
                Scotty T.H. wrote:
                > oops! I meant ...
                > on mouseWithin
                > end
                > or
                > on mouseUp
                > updatestage
                > end repeat
                UpdateStage is (almost always) Bad. Using updateStage "short circuits" the
                normal flow in Director. Always try to avoid updateStage.
                This behaviour, applied to a sprite, will rotate that sprite:-
                property spriteNum, self, active
                on mouseDown
                active=true
                end mouseDown
                on enterFrame
                if not(the mouseDown) then active=false
                if active then self.rotation=(self.rotation+1) mod 360
                end enterFrame
                on beginSprite
                self=sprite(spriteNum)
                active=false
                end beginSprite
                Add a sprinkling of mouseUp, mouseUpOutside, etc. to adjust behaviour as
                required. Did I mention avoiding updateStage?
                Andrew
