0 Replies Latest reply on Sep 11, 2006 7:30 AM by adams_chad
    Internal build error has occured - missing HTML
    adams_chad Level 1
      "Internal build error has occured"??????
      I can't seem to get this to go away, I continue launch and it tells me the "html" file doesn't exist. Sure enough it's not in the "bin" folder.
      I cleaned the workspace, restarted, even tried ot recreate the MXML application file (which is now just an application node, removing the possibility that something I wrote might be causing the problem). and still I get the compiler error!
      !SESSION 2006-09-11 09:22:04.560 -----------------------------------------------
      eclipse.buildId=unknown
      java.version=1.4.2_09
      java.vendor=Sun Microsystems Inc.
      BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
      Command-line arguments: -os win32 -ws win32 -arch x86
      !ENTRY com.adobe.flexbuilder.project 4 43 2006-09-11 09:30:10.401
      !MESSAGE Uncaught exception in compiler
      !STACK 0
      java.lang.NullPointerException
      at macromedia.asc.semantics.FlowAnalyzer.evaluate(FlowAnalyzer.java:891)
      at macromedia.asc.parser.BinaryExpressionNode.evaluate(BinaryExpressionNode.java:38)
      at macromedia.asc.semantics.FlowAnalyzer.evaluate(FlowAnalyzer.java:890)
      at macromedia.asc.semantics.FlowAnalyzer.evaluate(FlowAnalyzer.java:962)
      at macromedia.asc.parser.ListNode.evaluate(ListNode.java:27)
      at macromedia.asc.semantics.FlowAnalyzer.evaluate(FlowAnalyzer.java:5834)
      at macromedia.asc.parser.LiteralXMLNode.evaluate(LiteralXMLNode.java:28)
      at macromedia.asc.semantics.FlowAnalyzer.evaluate(FlowAnalyzer.java:3069)
      at macromedia.asc.parser.VariableBindingNode.evaluate(VariableBindingNode.java:48)
      at macromedia.asc.semantics.FlowAnalyzer.evaluate(FlowAnalyzer.java:2879)
      at macromedia.asc.parser.VariableDefinitionNode.evaluate(VariableDefinitionNode.java:32)
      at macromedia.asc.semantics.FlowAnalyzer.evaluate(FlowAnalyzer.java:1205)
      at macromedia.asc.parser.StatementListNode.evaluate(StatementListNode.java:36)
      at macromedia.asc.semantics.FlowAnalyzer.evaluate(FlowAnalyzer.java:2254)
      at macromedia.asc.parser.FunctionCommonNode.evaluate(FunctionCommonNode.java:87)
      at macromedia.asc.semantics.FlowAnalyzer.evaluate(FlowAnalyzer.java:4664)
      at macromedia.asc.parser.ClassDefinitionNode.evaluate(ClassDefinitionNode.java:86)
      at macromedia.asc.semantics.FlowAnalyzer.evaluate(FlowAnalyzer.java:938)
      at macromedia.asc.parser.ArgumentListNode.evaluate(ArgumentListNode.java:28)
      at macromedia.asc.semantics.FlowAnalyzer.evaluate(FlowAnalyzer.java:750)
      at macromedia.asc.parser.SetExpressionNode.evaluate(SetExpressionNode.java:39)
      at macromedia.asc.semantics.FlowAnalyzer.evaluate(FlowAnalyzer.java:580)
      at macromedia.asc.parser.MemberExpressionNode.evaluate(MemberExpressionNode.java:31)
      at macromedia.asc.semantics.FlowAnalyzer.evaluate(FlowAnalyzer.java:1255)
      at macromedia.asc.parser.ExpressionStatementNode.evaluate(ExpressionStatementNode.java:33)
      at macromedia.asc.semantics.FlowAnalyzer.evaluate(FlowAnalyzer.java:4382)
      at macromedia.asc.semantics.FlowAnalyzer.evaluate(FlowAnalyzer.java:2559)
      at macromedia.asc.parser.ProgramNode.evaluate(ProgramNode.java:63)
      at flex2.compiler.as3.Compiler.analyze2(Compiler.java:416)
      at flex2.compiler.API.analyze(API.java:2118)
      at flex2.compiler.API.analyze(API.java:2041)
      at flex2.compiler.API.batch2(API.java:296)
      at flex2.compiler.API.batch(API.java:901)
      at flex2.compiler.API.compile(API.java:1110)
      at flex2.compiler.API.compile(API.java:1022)
      at com.adobe.flexbuilder.project.compiler.Compiler.compile(Unknown Source)
      at com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilder.buildApplication(U nknown Source)
      at com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilder.build(Unknown Source)
      at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:593)
      at org.eclipse.core.internal.runtime.InternalPlatform.run(InternalPlatform.java:1044)
      at org.eclipse.core.runtime.Platform.run(Platform.java:783)
      at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:168)
      at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:202)
      at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:231)
      at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:234)
      at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:253)
      at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:282)
      at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:139)
      at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:200)
      at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
